Question about Toshiba 50HM66 52" Television
50HM66 Toshiba . no lamp, lamp good, replaced main power supply board,aux. power supply , and the lamp ballast, still no picture, starts up and trys then goes off and then re-try, I get 15 yellow blinks, any ideas ?
  • kenolson77 Aug 25, 2010
    Ok, checked connection and is good, used multi-meter, showing 102 vac at the bulb plug in socket connection, now what ?
  • Toshiba Master
  • 11,800 Answers
The 15 yellow blinks indicates a problem with the lamp engine. Either the lamp is not seated correctly in the TV set -  try removing it again, then pushing it in firmly, ensuring that it clicks into place - or the connectors are faulty - test the connectivity with an ohmmeter.
Posted on Aug 25, 2010
  • 1 more comment
  • Azrael SRL Aug 25, 2010
    In that case test the power source, especially the 5 volts line to the processor, since the error message is commanded by the control processor and it's clearly malfunctioning.
  • kenolson77 Aug 29, 2010
    I am not sure which board is the processor, I have identified the interface board, any idea ?
  • Azrael SRL Aug 29, 2010
    Just follow the connections fro the interface board right to the processor - you can't miss it, it's big.
I replaced the lamp on my toshiba 42HM66 and that worked for about 2 weeks. I ordered a new lamp and replaced it. Now the lamp light blinks amber and then the power light blinks green at about 30 second...
You will need to check if the output supply going to the lamp is good. If not the ballast will need replacement. That model is actually famous for haveing ballast issues. You can get the replacement ballast from www.tvcircuitboards.com they also assist with installation assistance if you require it.
Nov 07, 2012 | Toshiba 62HM95 62" DLP HDTV
Lamp unit Type: Y67-LMB The Lamp Burnt
If You are look to buy one Try TV Repair Kits.Com
Aug 19, 2011 | Toshiba 50HM66 52" Television
I have a Sanyo plc-xt25 LCD Projector and when I plug my ac cord in, the fans turn on but no lamp comes on. I changed the lamp and still no picture. What do I do?
Every projector lamp is equipped with ballast. The problem area is ballast. Either the ballast is not getting DC supply or the lamp turn ON signal from the projector main board or the ballast is faulty. Remove the lamp. Connect the projector to the mains supply. Check the voltage at the lamp connector inside the projector without turning it ON. It should be around 65 volts A/C. (Warning: Multimeter will get damaged if the projector power is turned ON due to generation of high voltage) If you find this 65 volts then it confirms that it has DC supply & the ballast is functioning. The ballast receives the the turn ON signal from microcontroller through opto-coupler on the ballast. The ballast opto-coupler can be checked by providing external 5V DC supply between pin 3 (+ve) & 4 (-ve) in turn switches ON the lamp. If this works then there is no problem with your lamp & ballast. The problem lies with the main board. If this does not solve your problem then give me the feedback.
Aug 04, 2011 | Sanyo PLC-XT25 LCD Projector
My tv trys to turn on several times but will not, I checked the trouble code tells me its the lamp . I took the back cover off I can see the lamp starts to come on but it shuts down and trys to restart...
Tv "LAMP" LED light is flashes or stay lite?The tv Projection lamp been in ur tv like 1 1/2 or 2 and tv been on and uses it like 4 or 5 hours daily?Yes tv projection lamp is dead and also might the board that call the Ballast board it dead too.This Ballast board,that board job is to help to ignite the tv projection lamp.
Jan 31, 2011 | Toshiba 52HM95 52" HDTV Projection...
I recently replaced my lamp light on my 50HM66 the tv worked great for about a week then while watching tv my screen went black and lost sound. When I turn on my tv it begins to shut off and on numerous...
Hey it sounds like you may have one of two problems here one you may have a bad lamp issue or two a bad ballast board I think at this point it will be a ballast it might be to weak to turn on the lamp or it is burning out the lamps to soon here is a link about Toshiba will change the way you think about this BRAND
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
PLEASE RATE THIS AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | Toshiba 50HM66 52" Television
I have the 50hm66 tv, replaced the main power supply board, and then the aux. power suppy board, still no lamp (lamp is good), 15 yellow blinks What you think ???
U hear alot of clickings,few mins tv is on?The board call the Ballast board is dead.This Ballast board help to ignite the projection lamp.
Aug 13, 2010 | Toshiba 50HM66 52" Television
I replaced the lamp- now the picture won't come up
U hear alot of clicking,when power on to the tv?Yes,the ballast board,that the board that help to ignite the projection lamp is dead.The Ballast board is dead.Change the Ballast board.
Jul 14, 2010 | Toshiba Televison & Video
Why does my samsung tv cut off by itself after 1-2 min and flash a red lamp button?
A little explanation first- this model (as do most Samsung DLP sets) will try 3 times to get the lamp lit before the microprocessor will give up and then the 3 lites on the front will blink indicating a LAMP failure. This process takes about 1 to 2 minutes. In order of probabilty, the failures are:
1) A faulty lamp and/or ballast. REPLACE LAMP AND/OR BALLAST
However, a faulty lamp and/or ballast are not the only things that will give this blink code-
2) If the color wheel has a bad bearing and turns too slow or not at all, the microprocessor WILL NOT let the lamp light, and then give a LAMP blink code. A bad color wheel will normally have some sort of abnormal sound- a low growl or high pitched whine is common. REPLACE COLOR WHEEL
3) ALSO, if the microprocessor (on the DMD board) in its color wheel rotation detection or processing fails, once again the lamp is prevented from coming on and you get a LAMP blink code. REPLACE DMD BOARD
IF THE SET EVER COMES ON WITH A PICTURE for even a fraction of a second or though it takes many tries, the lamp and ballast are good. The problem must be either the color wheel or DMD board.
Oct 26, 2009 | Samsung HLR5064W DLP Projection TV
Ballast
yes, at www.tritronicsinc.com. They are in Maryland and are a Toshiba authorized parts distributor.
C-Dog
Feb 07, 2008 | Toshiba 50HM66 52" Television
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 50HM66 52" Television Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
