Question about Philips MMS 203 Computer Speakers
I have the philips 2.3/mms203. Sound is only coming out of 1 speaker. If I wiggle the line in wire, I can get sound out of the 2 remotes, but not the subwoofer. Any thoughts on how to correct. Thank you
    President:
  • 2,600 Answers
In most cases when you "wiggle" the jack plug and there is a difference in sound output, the problem is going to be with the jack itself on the soundcard, whether it is integrated in the motherboard or on an expansion slot....there is a small falt tension spring inside the jack itself and overtime, this spring weakens and can no longer hold proper tension on the plug. The only solution is to either desolder the jack and remove it from the motherboard or card, or just buy another inexpensive sound card and install it into a free expansion slot. I do not think it has anything to do with the speakers themselves.
Posted on Aug 25, 2010
Philips lx3000
reason of Stereo no sound:
1 poor contact,signal line,socket connection problem.Acoustic power and signal wires to check clearly good contact.
2 Most common failure is bad capacitors,amplifier or power amplifier tube burning,this is our problem,but most of those are the devices themselves are not stable.
3 there happens no sound from one channel of the power amplifier failure,problem or circuit problem.
Nov 02, 2013 | Audio Players & Recorders
No sound out of my speakers model 5269480
on your amp under the back seat their are 2 plugs the one on the left which is the smaller of the 2 there is a Tan wire w/Orange stripe on it hook the remote wire from stereo plug which will be blue w/white stripe to that wire so it will power-up your amp...Bottom line, no amp = no sound,unless you figure what wires are the speaker wires and hook directly to your stereo plug............Its an easy fix
Oct 13, 2012 | 1994 Jeep Grand Cherokee
Whatever I listen to, the sound comes out of my tv instead of my speakers, although when i checked the speaker volume there working
Free PDF Instruction Manual at the link below.
http://download.p4c.philips.com/files/h/hts3154_05/hts3154_05_dfu_eng.pdf
Check Page 10 Point 2.
b Source buttons
- DISC/USB: toggles between DISC or
USB mode.
RADIO: toggles between FM and AM/
MW band.
TV: switches to TV mode. The sound
from the TV will output through the
connected speaker system.
AUX/DI: switches to the external device
that is connected to the AUDIO IN-AUX
socket.
MP3 LINE-IN: switches to audio device
that is connected to the MP3 LINE-IN
socket.
Apr 17, 2011 | Philips HTS 3154 Theater System
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Philips speakers wont work on dell desktop
I'm assuming you have plugged the speaker wires into the correct ports.
In Control panel, pick the sound icon and click to open it, do you have the sound driver showing (it will say no audio device if you do not).
If not, download the driver from the motherboard or sound card manufacturer
Check the desktop speaker icon is not disabled
Check the line out is set to high
Repost if these don't solve the problem
Jan 01, 2011 | Philips (DBMMS460) Computer Speakers
I have got Philips Home Theatre 5.1 (DSP 25000) , but it is not giving expected sound. Right Rear speaker and Left Fornt Speaker are not giving any sound . Please let me know the solution. I have connected...
Firstly make sure you have connected the speakers to the main system in an proper order. Certain system's have the name of the speaker's mentioned at every output line which is at the rear of the system. If you would connect the wrong wires then it eventually would not play the sound. once this is done make sure that the wires of each speakers are split into two at both the ends. They are normally coded in red and black colours at the tip of the wire. Check if the red of the wire is connected to the red of the system and so on for all the speakers. So try removing all your connections and do it all over in a proper way.
Sep 12, 2010 | Philips HTS3450 System
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
Audio
it is not remote problem please check the following 1 speaker or its wire for loose 2 check supply to sound section 3 check loose contact or loose part or print. 4 check for loose connector 5 check audio ic 6 check for signal to sound section ic is coming. hope this will help.
Oct 01, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Philips 32PT71B1 TV sound problem
it might be due to speaker. if it is ok then check for 1 loose connection in sound section. 2 speaker wire loose. 3 any capacitor in sound section might be faulty. 4 check supply to sound section 5 loose connector in sound section. 6 sound ic might be defective. if not tech.person take help from tv tech. hope this will help. good luck.
Oct 01, 2007 | Televison & Video
Philips MMS 203 Computer Speakers Logo
95 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
