Question about GE Refrigerators
Our side-by-side GE refrigerator is about eight years old, and on Monday, everything in the freezer was melting. Fortunately, we have a second ice box, and we transferred most of the food to it. We then set about to buy a new one, which because of our space restrictions, isn't easy. There is no ice, and the freezer is warm, but the cool side is still cooler than it should be after two days of no cooling. At first, I thought the problem was the compessor. Now I am not sure. The lights are on, establishing that there is power. Can you think of any problem besides the compressor to which this could be attributed? The ice box hasn't made a sound for three days.
  • 6,784 Answers
If you are not hearing the compressor cycle on and off in intervals and there is no air flow present inside the unit, this will confirm that there has been a severe malfunction within the units assembly. You will need to check the following areas for faults:
1. Compressor- Make sure this unit is functioning. if it is not cycling as designed, this will be the culprit. If it is cycling but very hot to the touch when operating, check the condenser coils for debris and clean them if necessary.
2. Compressor start relay - This is the main on/off switch that is attached to the side of the compressor. This relay, when energized by the main control board, starts the compressor. if the relay has failed, it will not start the compressor, thus, rendering the unit inoperable. Pull the relay off and shack it. If it rattles, replace it.
3. Evaporator fan - This is a very important part of the evaporator core. This is the principal air mover of the unit. If this fan fails, the inside freezer and refrigerator will not cool, at all. You will need to remove all the freezer shelves and content to access this unit. It is concealed behind a panel inside the back section of the freezer compartment. Once the concealment panel is removed, you will expose the core and fan. the fan can be tested with a multimeter for proper continuity. You can also jump the terminals with a jumper wire to see if it is still in working order. An external power source will be needed for this test. if the fan fails the test, replace the fan motor.
4. Condenser fan - This is also a very important fan. This fan is mounted near the condenser coils and can fail. You can test it in the same manner as the evaporator fan. replace the condenser fan if it proves to be damaged.
5. Main PCB(Printed Circuit Board)- This is basically your main power controller. This board routes power to all the fans and compressor unit located in the assembly. it also routes power to the lights and ice maker/dispenser, as well. This will be the most expensive repair, in this case. If all the above areas prove to be functional, the main PCB will be the culprit. You can easily locate this board. It is usually mounted on a bracket, near the compressor platform, or behind a concealment panel on the rear of the unit. Once you have gained access, visibly, inspect the board for burn markings at the relay mounts and jumpers. check the entire circuit board for discolorations like brown marks or black burn marks at the plug-in connectors. If this refrigerator is totally dead, this will be the cause.
6. Monitoring thermostats - These are located in each compartment. Replace each thermostat if all the other checkpoints prove to be ok and in good condition
7. Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
You will find the culprit in one or all of the areas stated above.
Posted on Aug 25, 2010
Frost in freezer, fan in freezer sometimes changes speeds, low pitch or humming noise,manualy defrosted it 1 month ago seemed to be fine for two weeks, vegies freeze in drawer. hotpoint hss25gfta 5 yrs old
If the defrost thermostat is bad it will need to be replaced, otherwise you will have to continuously manually defrost the unit. The noise you hear is probably the fan hitting the ice. The defrost thermostat assists in melting that ice about every eight hours.
May 15, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
MY FREEZER AND REFRIGERATOR DOES NOT STAY COLD. I HAVE G.E. REFRIGERATOR MODEL# GSS25SGMBS AND IT'S EIGHT YEARS OLD!
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system
Jan 21, 2011 | GE Refrigerators
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Our refrigerator is 2 years old a few months ago the back wall of the freezer was covered in ice and everything had melted. i took everything out melted the ice off the wall of the freezer and it started...
your defrost heater behind this wall isnt working to defrost the unit,a block of ice cant pass cold air,its either the heating element or the defrost thermostat or the main board in the rear area of the unit
Sep 13, 2010 | GE Refrigerators
Freezer not freezing during hot weather...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 03, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerator not cooling, freezer is working.
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE refrigerator/freezer - defrost noise
Blow it clean or check for loose bolts or broke springs.
Apr 18, 2017 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
