Question about Hunter Ceiling Fan Light Remote Control
I have a Hunter ( the augusta), model no. 21363 with lights and no remote and installed a Hunter Universal Fan and Light Remote Control, model no. 27227and (1) to turn the light on I must use the remote and not the wall switch (2) when in use after a while the lights go off by themselves. What can I do?
  • heber lugo Aug 25, 2010
    The fan is wired to one wall switch that has two wires (one black and one white). The remote and the receiver are set for CFL bulbs and the DIP codes are set in both.
  • 1,498 Answers
On item 1, yes, in order to use the remote the wall switch must be on. However, both can be used. Normally the wall switch would be used when leaving from or returning to the room, so it it is on while you are there.
While there the remote is used at your convenience.
Item 2 is either the receiver picking up a residual signal from an out side source or a flaw in the receiver.
If it happens every time, it's the receiver. An intermittent fade may be addressed by a frequency change.
Either one can be quite annoying. I would suggest an exchange while the warranty is in force.
Best regards
Mike
Posted on Aug 25, 2010
  • 2 more comments
  • Justin Case
    Justin Case Aug 26, 2010
    At least your remote works. I have been involved with at least two dozen Hunter and Hampton remote kits that had such limited range it was easier to pull the string than stand up and get close enough for the remote to work.
    Have a good day
  • Justin Case
    Is there anything on the remote kit warning about the use of fluorescent lights?
    That might be your problem.
    You cant use a fader with them
    Mike
  • Justin Case
    OK just read your response, take back the last
  • Justin Case
    Are the bulbs CFL's?
  • 2,841 Answers
First thing is make sure you have it set to the correct type light bulb you are using. It comes set for an CFL (Florissant Bulb) If you are using an Incandescent bulb then change it by way of a slide toggle switch inside the battery compartment. Also did you set the DIP codes on the transmitter and receiver exactly the same per the instructions? To manually turn the fan/light off you can always just turn the power off at the wall switch. One thing that might be the problem is how the fan is wired. It may be wired on 2 wall switches. One wall switch may be for the fan and the light may be on a 3 way wall switch system which will have a switch at 2 locations. You say it goes off all by itself which makes me think this is the case. Turn the light on and then look for a wall switch at 2 locations that control the power to that light. It is very common to wire a ceiling fan with the fan on a single switch and the light on a 3 way switch at 2 locations. I wire them this way all the time for connivence of the home owner.
  • NOT ME Aug 25, 2010
    Ok, as I understand it your problem is that the light goes out all by itself. If that is the case they there is some sort of interference coming from somewhere. If you are near an airport, police station, radio station, or anything else that may be broadcasting an RF signal you may be getting interference. Change the DIP codes on the receiver and transmitter to see if that stops the interference. The fact that you must use the remote turn the light on is normal. You can turn the light off with the wall switch but you cannot turn it on. That is the purpose of a remote. You dim the light by holding the on/off switch on the remote in.
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan remote 27144
reset the code and test again.
God bless you
Feb 18, 2013 | Hunter 27144 Universal Remote Controls...
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Changing switch box to universal remote but the number of wires don't match switch out hunter model 85464 switch box for hunter universal remote model 27227 060 but the number of wires done match and odd...
Hi. Your best bet here it to call Hunter directly as they have people on hand with all of the schematics who will assist you.
888-830-1326
Monday – Friday 7am – 7pm CST
Saturday 8am – 5pm CST
J.
Jul 22, 2010 | Hunter 52" Ceiling Fan With Light And...
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Mar 27, 2010 | Hunter 27185 Remote Control
Hunter ceiling fan (model no. 25736) and light not starting
Home Depot sells universal remote systems (transmitter and receiver) for around $30 (in Delaware & Pennsylvania) -- don't know price in Chicago).
I'd just replace it. Hunter may be correct that they are the only source for the receiver, but if you get a new transmitter as well, you don't need their receiver. The labor is the same either way.
Charlie
Aug 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Hunter fan remote control
Logitech makes a universal remote that uses RF (radio frequencie) which could be programmed for the cieling fan.
Jun 08, 2008 | Universal Remote Control Hampton Bay...
Dryers Logo
281 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
