Question about Canon Cameras
Canon Powershot SX110IS shows "card locked" in screen. Checked card to make sure it was not locked and tried other cards. Camera will not take pictures.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 26, 2010
Testimonial: "This fixed the problem in seconds. No other site offered such good advice. "
  • grandmakathy Dec 25, 2010
    Thanks so much! This worked great! Whew!
    Kathy
Memory card locked
And you looked if the card was locked?
The 64GB card is unlocked the 32 GB card is locked. So make sure the switch is up when you see your card like these two.
When you are sure your card is unlocked, just check if all contacts of the card and in the camera are still clean, shiny, and straight. (no bent in any contact)
Jan 18, 2014 | Canon PowerShot A490 Digital Camera
Camera says card is locked canon powershot sx100
"Card is locked" usually means that the little write protect switch on an SD card has been set to stop the card being written to. Seems unlikely that it would happen to two cards in a row, but it is worth checking this.
Nov 05, 2010 | Canon PowerShot SX100 IS Digital Camera
I keep getting a communication error while trying to upload my pictures for camera Cannon SX110IS. what is wrong?
There are a couple of things you should try, remove the memory card from the camera and try connecting, if you get no error then chances are your memory card is corrupted.
If you still get an error then start looking at the cable you are using, try another if you can get one, cables are easily damaged.
You should also try checking the camera settings for USB connection and make sure it is set to Mass storage
Oct 27, 2010 | Canon PowerShot SX110 IS Digital Camera
My Canon PowerShot SX110IS shows "Card Locked!" on the screen even though the memory card is not locked.
I am having a similar problem. It worked fine. Took pictures in AM. By PM I received the same message. The memory card is NOT LOCKED, yet it is reported as so.
Aug 17, 2010 | Canon Powershot SX110 IS Digital Camera...
I have a canon powershot sx110is and when i turn it on it will not take any pictures but instead gives the message "memory card error." When I put it to the display mode it says the same message plus...
First see if the camera will work without the memory card installed. Then format the internal memory using the camera's setting as described in the manual.
Then turn OFF the camera and insert the sd card. Turn on and reformat the card too.
Make sure you have NEW batteries or sometimes things go flakey.
Dec 22, 2009 | Canon Powershot SX110 IS Digital Camera...
Canon A620 LCD shows "memory card locked" for each card I insert
This worked for me!  I have the Canon Powershot SD780 IS and although my card WAS NOT locked, the camera "malfunctioned" and the switch in the camera needed to be gently pushed back IN, not DOWN on my specific camera type.  This is great, I was just going to go out and buy another camera today!  Thanks for the post Stephan!
Nov 10, 2009 | Canon PowerShot A620 Digital Camera
Canon Power Shot A480 memory card error showing on screen I have checked side locked button
If it's a brand new card, it needs to be formatted with the camera. If it's been used before, the files may have been corrupted when plugged into your (or another) computer.
Nov 08, 2009 | Canon PowerShot A480 Digital Camera
Screen shows 'card locked' ,Unable to take photos Memory card checked. It is not 'locked'. Exchanged yto new card but still ;card locked'.
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Oct 20, 2009 | Canon PowerShot A550 Digital Camera
Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
May 20, 2009 | Canon PowerShot A470 Digital Camera
Card locked
Have you tried looking at the memory card? Sometimes there is a switch on the card itself that slides up and down to lock, or unlock the card for usage. Hope this helps! (It should be white, and a semi-translucent plastic.)
Sep 24, 2008 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
145 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
