Question about Simplex Kaba Ilco Unican 1000 keyless lock
What is the default code for unican 1000 keyless lock, how to change combo on it?
  • 2692 Answers
SOURCE: want to reprogam keyless lock
Turn knob once. Put in present combination. Open screw on the top, Use a small rod or drillbit  that will fit into the hole. Press straight down on a lever that is inside of the hole,until it clicks. Turn knob completely(once) to clear old combination. Put new combination in, making sure that a click is heard upon pressing each button.  Try knob with both the old and the new combination. Each digit may be used only one time in the combination.
Posted on Mar 05, 2009
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 963 Answers
SOURCE: I have a Simplex Kaba
I believe you can find this to be relevant:
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Where can we order the key to change to combo?
A Df-59 key can be purchased through this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx Call them to order it @773-809-3667 Obviously it isn't really $0.
Or try this source:
The tenth item down is the key & spanner wrench for $9.
Mar 12, 2012 | Simplex Kaba Ilco Unican L1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I changed my combination and dont know what i set it to
If you forgot the combo you will need to reprogram it. If you can not get in to open the door to reprogram you can email llco at info@lilocksmith.com for an override code.
Good Luck
Dec 28, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Bought a house with a Unican 7000 series keyless lock on it. I have the current code but want to change it. Can someone tell me how I can change the code?
Yow will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Oct 30, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do you change the handing on a unican 1000
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
you can download a manual here. I assume you mean to change from left hand door to right hand door? The manual will describe how to do that.
Jul 13, 2010 | Simplex Kaba Ilco Unican LP1000...
ENTERED CODE RED LIGHT GOES ON AND NORMAL SOUNDS HEARD BUT GREEN LIGHT DOES NOT GO ON. AHNDLE MOVES FREELY (WILL NOT LOCK DOOR) rECENTLY CHANGED BATTERIES
The battery change probably reset it to defaults, do you have the manual, Try the default code.
if you don't know or don't have a manual please post me the brand and model.
Jun 25, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Lost code for keyless unican lock
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
117 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
