Question about Roper RAS8445KQ Top Load Washer
How can I remove the back panel so I can replace a belt?
    President:
  • 1,430 Answers
That machine is direct drive, it uses a motor coupler no belt. Here is a link that will show how to disassemble and replace the motor coupler if that is the problem http://appliancehelponline.com/topdirectdrivevideo.html
Posted on Aug 25, 2010
Asko T702C Service Manual
That is a pretty easy fix without the manual. Take off the top by removing screws on the back top. Remove the sheet metal screws around the perimeter of the the back panel. Pull the drum off the front enough to drop the belt in front of the drum. Put the back panel back on. Now you can thread the belt back into place. The belt runs with the ridges on the spindle of the motor and on the smooth side on the tensioner.
You should replace the pulley idler when replacing the belt, also. I learned this the hard way and snapped a 5 month old belt.
Jan 19, 2014 | Asko Dryers
Replace belt
  • Disconnect the power source from the dryer. You can unplug from the wall outlet, remove the fuse from the fuse box or flip the breaker in the panel box.
  • 2
    Pull off the front panel of the dryer. Remove the screw in each corner at the bottom of the dryer's front panel. Lift up the front panel until the two clips at the top disengage. Remove the two screws that are found beneath it at the corners to remove the cabinet top.
  • 3
    Remove the belt by releasing the tension applied by the movable idler pulley wheel. The belt loops over the drum, under the idler pulley wheel and then around the motor's drive pulley.
  • 4
    Discard the used belt. It is fine to just throw it in the trash.
  • 5
    Install the new belt by pushing in on the idler pulley arm. Make sure the new belt is placed flat along the exterior of the drum.
  • 6
    Replace the screws back into the dryer's front panel. Screw them in tightly so that the panel will not fall off or jiggle loose.
  • 7
    Reconnect the power source back to your dryer. Either plug it back in or flip the switch in the breaker box.
Jan 11, 2012 | Amana DLE330RAW Electric Dryer
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
How to open upright washer dryer to change belt on washer
FIRST TURN OFF THE POWER TO THE MACHINE,
LOOK AT THE BACK AND YOU SHOULD SEE SCREWS AROUND THE BOTTOM PANEL REMOVE THEM AND THE PANEL YOU SHOULD SEE THE DRIVE BELT CONECTED TO DRUM PULLY AND THE DRIVE MOTOR LOOK FOR A TENSIONOR LOOSEN IT AND REMOVE BELT TAKE THE BELT TO AN ELECTRICAL AND PLUMMERS SUPLLY STORE FOR REPLACEMENT BELT REFIT IT AND REPLACE PANEL AND YOUR MACHINE SHOULD WORK FINE , GOOD LUCK .
Nov 26, 2009 | Kenmore 98702 Stacked Washer/Dryer
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Belt needs replaced
hi. thanks for the question. to replace belt . lift up top, remove front panel, slip belt over drum. reinstall front and top, and clean all lint . pull dryer from wall ,remove back panel . motor on right, idler pulley on left, pull belt through idler and to your motor. thanks the appliance doc thanks the appliance doc
Oct 02, 2008 | Dryers
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Roper RAS8445KQ Top Load Washer Logo
16 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
