Question about Frigidaire Heating & Cooling
My frigidare wall mount air conditioner won't blow cold air? Can this be fixed?
  • Frigidaire Master
  • 43,501 Answers
<P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Hi,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN><o:p>&nbsp;</o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Here is a tip about troubleshooting your air conditioner...<o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>There are many things that can cause your air conditioner not to cool…<BR><BR><A rel='nofollow' href="http://www.fixya.com/support/t4975332-c_run_only_humming_noise_when_turned" target=_blank><FONT color=#0033cc>Air Conditioner</FONT></A> Trouble -Review the <A rel='nofollow' href="http://www.fixya.com/support/t5003406-compressor_failure_sends_out_hot_air" target=_blank><FONT color=#0033cc>Possibilities</FONT></A> <BR><A rel='nofollow' href="http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi</FONT></A><BR><BR>heatman101 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></SPAN></P>
Posted on Aug 25, 2010
Why is hot air blowing out of air conditioner
If it is a wall mounted one like the one in the picture and it is fairly new, and possibly a Fujitsu or LG, it may be by design. Modern AC can run backwards to become a heat pump and takes the cold air from outside, extracts warmth and blows it inside for the winter months. The remote has different symbols for heat or cool.
If not new, and only blows cold it needs refrigerant gas, or at worst a new compressor..
Oct 30, 2015 | Heating & Cooling
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
Have a frigidare wall ac (FAA067P7A). Worked 1st year we had it but problems after. Only time compressor kicks in is when we hit reset button. Then cold air comes out for couple minutes then compressor...
The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
Aug 03, 2011 | Frigidaire Compact Air Conditioner
The AC fan does't want to begin to spin on its own. if I give it a little help, it will begin to work. Why wont it start on its own the fan will spin very easily and is not restricted at all it...
Hello, sounds like you have a bad capacitor, the capacitor gives the motor a boost and improves the running effeciency of the motor. Replace the capacitor it should fix the problem.
Mar 18, 2011 | Frigidaire Heating & Cooling
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
A/C UNIT FANS BLOWS NO COLD AIR COMPRESSOR KICKS ON THEN OFF
check fins in the condenser coils (the fins on the outside part) for obstructions or alot of bent fins. should be free and clear. but chances are the freon level is low. can be serviced, but may be cheaper to replace.
Jul 20, 2009 | Frigidaire FAS156N1A Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Not blowing cold air
Sounds to me like your compressor is not operating, first check the filter to make sure its not pluged up, if thats not it, you will need a qualified service tech to come a diagnos it for you, but sounds to me like the compressor is bad, hope that helps
Jan 20, 2009 | Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
