We are selling our house and have been leaving the air conditioner on for the last several days at 70. It has been keeping the house cool for visitors when we are at work. Yesterday I came home from work and the house was warm. I checked the air conditioner and it felt like it was blowing just air. Checked it throughout the night and still blowing just air, not cold anymore. I am thinking it ran out of coolant. I am not an expert or know anything about air conditioners. If you could give me your thoughts on this I would greatly appreciate it. Thank you.
  • 2,841 Answers
It can be many things like a loose connection. It can be low of refrigerant or it can be the condenser fan has stopped working. Considering you are selling the house just call a qualified HVAC repairman and have it repaired.
Posted on Aug 25, 2010
LG a/c not cooling
you may have freon leak, does the compressor turn on.?
Jun 02, 2013 | LG M5203L Air Conditioner
User manual for jnc JAC-24Y2???- want to know what the optimal setting for heating temp is for economy in the unit. We seem to have to have ours set quite high to get the unit to run consistently. If we...
Normal settings 70 heating 74 to 76 cooling, I try to leave my cooling a 76 and keep it there. 76 degrees feels good if its 95 or hotter out side and the lower you set it the more it will cost.
Jul 03, 2011 | Heating & Cooling
If the thermostat says 89 which is house tempture, what should I put the air condition on to off set that temperature to make it cool in my house, right now air condition is set for cool @ 70, and house...
You have done everything right there...something is wrong with your A/C...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 28, 2011 | Ruud UBHC Air Conditioner
When my unit was installed, the house was 1200 SF, now it is 1800 SF. Will this unit still cool my house in the summer?
The answer depends on several factor but as a general rule I size systems at one ton cooling per 500-600 square feet. Therefore I think you will find on very hot days that your a/c is going to be working hard to keep up. Thank you
Nov 30, 2010 | Ruud Matching Split Air Conditioner
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
My house will not cool. I have the thermostat set on 70, and it barely makes it to 75. Before I call my landlord and have him check it out, is it just because it is so hot outside (I live in AL and then...
Hi, the design temp for air conditioners is 90F. When the outdoor temp is over this you may notice it not keeping up. However, there are some things you can check. First, check the air filter. Next check the indoor and outdoor coils to see if they are clean. These coils need to be clean to work efficiently, especially when it's very hot. You can get some cleaner for the indoor coil that does not have to be rinsed off. The outdoor coil will have to be rinsed though. Of course there's always the possibility that the refrigerant charge is low. Let me know what you find.
Aug 05, 2010 | Heating & Cooling
Poor cooling. High bills when heating.
see if the lines the big one if it is verry cold or frosted let me know
Apr 08, 2010 | Goodman GPC1330H21A Air Conditioner
We just turned on our central air conditioner last night. today the temp of the house was 80 degrees. someone in the household placed the tempature on 70 degrees cool on auto. we have not felt any air...
Did you hear the indoor unit running (the fan blowing)? If so, there's a good chance that either the filter is plugged or more likely, the evaporator coil is iced up and preventing any air from flowing into the dwelling.
This points to a refrigeration issue with the unit - possibly a leak or low refrigerant charge.
You should turn the A/C off and leave it off for a day. Then just turn the indoor unit fan on by selecting the fan "on" setting on your thermostat. If you feel air coming out of the vents, then the evaporator coil was probably frozen.
If you are not an HVAC tech, it's time to call for professional help.
Apr 07, 2010 | Heating & Cooling
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Air conditioner
Yes, first turn your thermostat to the off position. Try to reset both fuse boxes again. If the ac comes back on problem solved, if not fuses and or breakers may need to be replaced. Let me know if this helps and we can go futher into why the ac is not only reaching the temp at night. Thanks
Aug 10, 2007 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
