Question about Refrigerators
Having trouble replacing realy for compressor on a Whirlpool refridge
    Scholar:
  • 149 Answers
Send a picture of the relay and i can assist you hvac.tech7872pr@gmail.com
Posted on May 06, 2008
My Whrilpool 3 Door Protton refrigerator was found cooling only freezer compartment, not refrigerated compartment. Local mechanic told that it is a defrost problem and replaced two bi-metal thermostat
this seems to be a major issue with whirlpool and kitchenaid multiple door refrigerators. The defrost timer device on the compressor does not function properly or fails and the cooling coils freeze up. Check the little fan that pulls air through the freezer coils to make sure it is running (that cools the refridg) if not running then it is bad and causing problem. Otherwise you have another bad defrost relay on the compressor. It's easy to change and cost about $25 at the parts store. I just defrost mine every six months or so since none of the ones I tried work very well. Its just a bad design that is still propagating in whirlpool devices.
Jan 06, 2015 | Refrigerators
Compressor requires 2 or 3 or more tries to start.
If the model number is correct and you replaced the=>12555902 Start Relay with Overload along with the-> 65889-4 Run Capacitor
and still having trouble the compressor may be defective due to binding because of wear, age, factory defect or you are trying to restart too soon after the compressor last stopped. No promises of a fix but the=> URCO810_Supco_Start_Relay_3_n_1
may be useful in a worn binding hard start compressor but may last a good long while Sea Breeze
Nov 17, 2012 | Maytag MBB2256GES Bottom Freezer...
I need more details diagnosing our refridge problem. I am getting click, buzz, click, but do not know how to check the start relay. Model is whirlpool ed25pqxdw01
if its making a buzzing noise than its your compressor you can put a amp meter on your compressor and it should not take any more than 10 amps to start
Mar 08, 2011 | Refrigerators
My whirlpool refridgator, lights are on hear a faint working sound. not cooling at all. I believe the problem is the adaptor fan, where is it and is this the problem,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 06, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
My model KSRL25FRST04 refridge is not cooling and the freezer is thawing. There seems to be no control lights on for the cooling selections. The lights in both sides are on and so is the ice and water...
Compressor may be shot, but read the Compressor realy and cap. tip first... it may be easier then a compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Oct 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor going
It is possible as Amana is now owned by Whirlpool which uses "Embraco" compressors. These have had issues. Contact the factory and tell them to send a supervisor.
Apr 22, 2009 | Refrigerators
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Whirlpool refridg side by side
This sounds like the compressor is bad. The clicking sound is the start relay trying to start the compressor and cannot. You stated that it was only four years old. Check the warranty for your frig. Most carry a five year warranty on the compressor.
Nov 10, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
