Question about Xerox WorkCentre XD100 All-In-One Laser Printer
I have a workcentre X125f and the panel flashes CH and the toner icon is lit up Red. Do I need a new toner?
  • 1,110 Answers
The actual definition of the CH code is the toner cartridge is missing or not inserted properly. If the toner cartridge is there then I would try reinstalling it. Several times if neccesary. If the toner cartridge were just empty you would not get the CH code. Just the toner light. If re-installing several times does not help then you MAY have either a defective toner cartridge or a problem with the electrical connector that connects the toner cartridge to the copier when it is installed. You can find this connector by looking at the back of the toner cartridge as well as in the back of the "port" where the toner is installed.
Good Luck and Thank You for using Fixya.
Posted on Aug 25, 2010
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Red toner light flashing
Dear sir; CH appears on the window means somewhere the door didn't close, when you close all door the red light will be disappear. try it out and let me know if you need more help, good luck, DON'T FORGET GIVE ME A RATING, THANK YOU , HAVE A HAPPY HOLIDAY !!!
Dec 22, 2008 | Sharp AR-M205 Copier
Red light lit next to wrench icon on top panel.
Tell me yours e-mail address and i will sent you the manula the red lit may be a toner end lit
Nov 12, 2008 | Ricoh FAX2500L Plain Paper Laser
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
ERROR MSG CH
A CH code means the toner cartridge is not being sensed.
Could just be not seated properly. Open the front and remove and reseat the toner cartridge.
It may be empty also.
Aug 24, 2008 | Xerox WorkCentre XL2130f Laser Printer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
AR-150N series copy machine. Making loud clicking sound and has CH on display. Need manual for this machine also.
CH means door is open, flashing CH means problem with toner cartridge You may need to replace the toner cartridge, the op manual can be downloaded at: http://www.sharpusa.com/files/cop_man_AR-151.pdf
The 151 is the same to the 150
Hope this helps you...
Jun 06, 2008 | Sharp Office Equipment & Supplies
AR-207 copier has "CH" flashing what to do?
CH code is usually associated with the Crum chip located on the back of the toner cartridge that gets 5 volts dc from the power supply and resets a counter on the main board to tell the copier approximatley how much toner you have when you insert an new toner. What may have happened, is the same 5 volts dc is shared with the laser unit and the when the laser goes bad it may cause the CH code just before it gives the E7-03 code for the laser due to the 5 volts being drawn down by the bad laser. If turning the machine off and back on with the new toner doesn't fix it then you either have a bad chip on the new toner or a bad LSU (laser Scanner unit)
Please don't forget to rate our answers please.
Dec 14, 2007 | Sharp AR-207 Copier
Keeps showing J1 error, toner light is flashing
The J1 error means the toner cartridge needs to be replaced. Since you just replaced the cartridge, you should remove the cartridge and repeat the following steps.. Shake the new toner cartridge horizontally four or five times and then remove the cover. Slide the new toner cartridge in until it locks in place. It sounds like the cover may still be on the cartridge.
May 14, 2007 | Xerox WorkCentre XD103F All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
