Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven won't heat up. F-3 appears looks like a
Oven won't heat up. F-3 appears looks like a sensor problem.... how do I fix it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
New oven won't heat
1.Check sensor connection. 2.Measure sensor resistance (1080 Ohms at 70 degrees F. Add 2 Ohms per degree F). 3.If resistance is not valid, replace sensor. 4.If sensor resistance and connections are good, then check for welded-closed relays on the control.
Here is the sensor to order if it is bad.
Nov 28, 2012 | Ovens
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
Whirlpool electric oven model RBS305PDQ12 won't heat after a partial cleaning cycle did not finish. Replaced the thermocouple less than 2 months ago is there anything else that can cause this
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Ovens
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 13, 2011 | Jenn-Air Ovens
When the oven is set, it heats for about five minutes. Then "F-2" appears on the screen and it shuts itself off completely.
F2 Oven temperature is too high
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Dec 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Heat cuts off on oven after being on for about 30 minutes. Code F2 appears.
Hi, F2 code means that the Oven temperature is too high.....
Solution:
  • Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
  • For SELF CLEAN models: check door lock operation.
  • Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember:
  • Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Oct 14, 2010 | Whirlpool RBS275PD Electric Single Oven
Code F-3 or F-5 appears when oven heats
this is usually a temp sensor probe problem.check you wiring between the probe and the electronic control board. at room tempt check the resistance on the probe if it less than 500 ohms replace the probe.
Feb 23, 2010 | Magic Chef 9512 Electric Single Oven
F-3 has appeared twice on our GE Elec. oven. Model JKP14WOV1WW
some GE f3 is a bad oven temp sensor. look inside its a metal rod look
Feb 13, 2010 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
26 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
