Question about NEC DS1000 66-Block with AMP connector (S66M1-50-3T25) Phone (S66M1503T25)
NEC DS1000 Program 0505 Swap Extension, Swap Failed...no access to block. How can I get swap the extensions?
SOURCE: NEC Dterm 80
http://www.battscom.net/User%20Guides/IPK/IPK%20Multiline%20Telephone%20UG_2b.pdf
Posted on Oct 10, 2008
  • 149 Answers
SOURCE: Programing someone's extension on to the phone
you need to get into program mode and assign key data for that extension.
tech support at ldtsnj.com
Posted on May 02, 2009
  • 149 Answers
SOURCE: Change Extensions on NEC IDK Phone?
It is easier to move the wires but if you know how to go into programming than change the extension numbers on the ports in mb 4-10
Posted on Jul 08, 2009
consultel1
  • 860 Answers
SOURCE: Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Posted on Sep 28, 2009
vanherringto
  • 1738 Answers
SOURCE: Have a NEC DTU-16D-1a and the feature light is
Thanks for visiting FixYa!
Unfortunately, FixYa does not currently have a User Guide for your phone which would enable me to assist you with your problem.
However, a User Guide which contains the Instructions and Feature Codes for your phone can be purchased at the following website. It's the only one I could find. You may be able to find your answer in their User Guide if you don't have one.
Click here:
http://www.telephonesonline.com.au/cordless-wireless/NEC-Xen-Master-Axis-phone-system-manual-instructions-user-guide-download.html?printable=Y
Posted on Feb 24, 2011
How do i change the time and date!? nec 80570
On an Elite or IPK phone system, which are just some of the systems that use this phone, you make the time change from one of the 2 main operator phones, x100 or x101. Without lifting handset, press Feature, 9, #, the phone goes into time program mode. Enter the hour and the minute, press Feature to exit and write OR press HOLD to get to date change, enter day of week as 1 through 7, HOLD, enter month as 1 through 12, HOLD, dial in year, and press Feature to write and exit. The other systems that use this phone aren't as easy. Good luck.
Sep 03, 2014 | NEC Lands Phones
Systeem 4/24 sl000
I think its always busy because it has a fault on that handset or its cradle. Swap the 2 over, and see if the problem moves to the new location, if it does the handset or cradle is faulty.
Dec 20, 2013 | NEC SL1100 1100061 Digital 12 Btn Black...
How to change name display
There is no user programmable way to change the name display on your phone. On NEC systems, you have to go into programming mode and access the memory block for extension names. Sorry.
Jun 01, 2011 | NEC DTH-8D-1 Corded Phone
How can i change the extension numbers and names on kx-t7630
It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Carl
Aug 26, 2010 | Panasonic KX-T7630 Corded Phone
I want to swap out a 9640 with sticky keys for a new 9640. How do I reassign the same extension to the new phone?
When the new extension boots up, it will ask for the extension number and password. Simple as that.
Jul 27, 2010 | Avaya 9640G
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
Sep 28, 2009 | NorStar M7310 Corded Phone
NEC Phone Reprogramming
Turn Set Relocation ON - Feature 84 and just move it.
If you are swapping phone locations:
  • Turn Set Relocation ON - Feature 84 then
  • From the phone being moved, press Speaker 61
  • Enter the swap extension
  • Enter password when prompted (probably 10 zeros)
Confirmation should appear on LED and you should hear a beep.
Jun 03, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Oct 12, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC DS1000 66-Block with AMP connector (S66M1-50-3T25) Phone (S66M1503T25) Logo
127 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
