Question about Maytag MDE5806AY Electric Dryer
Dryer runs for about 10 seconds and then turns off
Dryer is only 2 years old. I tried several different cycles. In any setting the dryer only runs for about 10 seconds. I checked the filter which is clean. I also check that I'm getting good airflow out the vent. I also experimented with a full load of clothes, just a couple of items and then also empty. After the dryer stops, all the lights on the cycle selector knob blink for a couple of seconds and then go off.
  • ATLPML May 07, 2008
    Completely forgot to put that in the original message. It's a Maytag dryer model number MDE5806AYW
  • ATLPML May 08, 2008
    Checking the dryer some more I noticed that the drum is a little hard to spin. On some of the posts I noticed this as a troubleshooting step. How easily should the drum spin?
    Genius:
  • 3,422 Answers
HI,
I have got really useful info. for you which may help you out.
Please CLICK HERE and go through the posts in the forum.
Goodluck..
Posted on May 05, 2008
  • 2,336 Answers
There might be a latch switch loose or defective that does not let the dryer engage the rest of the circuitry to function properly.
Click here to know where to find that latch switch.
There is more info by clicking here to troubleshoot your appliance.
  • Jaime Hernandez May 05, 2008
    Read the info in this post from other users that have experienced more or less the same problems.
    Click here for info on how a defective motor behaves when not functioning properly.
    Brigadier General:
  • 3,614 Answers
Can you provide or specify whats is the maker/model and part # of your machine..
thank you
Maytag dryer MD-24 error symbol?
The dryer completes the cycle you have set. If you do not remove the contents at the end of the cycle, the dryer performs the start-stop routine you describe until you get around to removing the contents. Eventually even the start-stop routine ends and the contents just lie in a heap until removed
Mar 11, 2013 | Dryers
Buzzing noise
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | Samsung DV419AGW Dryer
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
Jul 01, 2009 | Dryers
Kenmore dryer 70 Series doesn't shut off, timer continues to run
there are 2 different kinds of units made back then.
one has a push to start button that could have a stuck contact causing the unit to think you are pushing the button and want it to run again.
the other could have a stuck motor switch and thats not available separately. you would have to replace the motor. try to clean any lint out of the motor if you have that type. use compressed air to blow the lint out of the motor. it usually works to get the lint out and it can cause the switch to stick.
Dec 28, 2008 | Kenmore 63942 Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
It takes several auto cycles on regular heat to dry a load of laundry when I think it should only take one. What's wrong?
first, check your exhaust, you have to make sure there is no buildup at all inside it. this is the most common problem to cause this. if lint gets backed up, there is a sensor that shuts down the heating element after only a few seconds. hope this helps
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
F 70 code on the Kenmore elete smartheat HE4
hello Whgispers42,
Huuum At your service!
You said,
We frequently have to start the dryer several times during one load. The dryer will run fine for a while then all the sudden give 3 beeps and then the F 70 code. Sometimes when you go to start the dryer you can press power and the panel will light up for about 3 - 5 seconds and then shut off again, this will happen several times in a row. We have been unable to solve this issue ourselves and are becoming very frustrated since this washer/dryer set are less than a year old. Any help you could offer would be greatly appreciated. (If we are unable to fix this problem soon, it is likely that the dryer will make a sudden leap from the second floor window to the backyard)
Try this first!!
This is an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not help, you said the machine is not one year old.
All appliances have a 1 -year warranty and the service and parts are free for that first year!
I hope you succeed with my recommendations.
Please contact me with your progress1
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Jul 27, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Maytag MDE5806AY Electric Dryer Logo
248 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
