Question about Garden
Olympic264chainsaw,have spark,105lbs.compression, air and fuel flow but wont start
  • 905 Answers
Check the woodruff / flywheel key. It may be partially sheared, throwing off the timing.
Posted on Aug 25, 2010
My 1995 z28 5.7 cranks but wont start. fuel pump fuel filter fuel pressure battery terminals regulator spark all check and are fine. could it be mass air? or???
No pun intended, did you check the spark plugs? Regap. Compression, Exhaust clogged. Or a vacuum leak would give you same headaches.. O2 sensors. ect. Have it scanned before you sink more $ into it. All the no start exhaust may be clogging your exhaust? Check it out. Keep in touch, I love Diagnostics of this kind. PS. even a faulty part installed. good luck
Sep 19, 2015 | Cars & Trucks
My car cranks but will not start RVR GDI mitsubishi
Check all fuses first, then with an assistant, check for spark with a spark tester. if there is spark at 2 plugs, check for fuel pressure at the fuel rail with a gauge. Engines need three things to run, fuel, spark, and compression. If there is spark and fuel, do a compression test, if the timing belt jumped/broke, you won't have any
Mar 03, 2015 | Mitsubishi Cars & Trucks
Saw wont start, getting fuel and spark
Try starting it with the air filter removed. If it starts, clean the air filter. It could also be the fuel filter. If you replaced all the fuel lines, make sure you didn't get the oil line mixed up with a fuel line
Jan 25, 2015 | Poulan Garden
Wont start
1. Fuel pump control circuit
2. Spark plugs
3. Ignition system
4. Injectors
5. Mass air flow meter
6. Throttle control system
7. Air induction system
8. Engine compression
9. Engine oil viscosity.
Dec 28, 2013 | 1997 Hyundai Elantra
My 2004 chevy malibu classic 4 cyl wont start its
There are four things required for an engine to run: air, fuel, compression and properly timed spark. If you have fuel and timed spark, the only two variables are air and compression. Air is not the likely problem, and compression should be good unless you blew a head gasket or the rings in all four cylinders. How did you determine that you have fuel and spark? Those are the two most likely problem areas.
Oct 10, 2013 | 2005 Chevrolet Malibu
88 honda accord will start but not stay running its getting fuel, air flow and spark
Generally speaking, if the engine dies it has to be loosing one of the three components, fuel spark or compression.
A common problem with Honda cars is the fuel pump relay.
You'll have to figure out what is being lost when it dies to proceed.
Jul 31, 2012 | Honda Accord Cars & Trucks
1989 Cutlass wont start
the filter on fuel pump might be clogged as well or fuel pump needs replaced
Oct 01, 2009 | 1989 Oldsmobile Cutlass Ciera
Car gets spark and fuel and wont start what can it be
does it sound weak when you go to crank it if so check the compression! check the gap on your spark plugs,check the air flow
Sep 30, 2009 | 1996 Ford Contour
Getting fuel...getting spark...still wont start...whats up?
Get a can of CRC brand air flow sensor from your local auto part store.
ECU may be getting low reading from air flow meter.
Folk use K&N may over oil the filter and coat the senor element with oil.
After cleaning,disconnect and reconnect the ground cable to clear data.
Open gas cap to equalize the pressure.......just is case you soak the emission canister when topping of the fuel tank.
Jul 15, 2009 | 1995 Chevrolet C/K 3500
Wont start
Hello;
If it starts with ether then you have spark, compression, and air. All you need is fuel. Make sure that you have fuel at the carbs and that the fuel is flowing to the cylinders. Check that the petcock is open and free of debris. Hope that helps;
Thanks;
Rich
RPM Northwest
May 19, 2009 | 1977 Suzuki GS 750
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
