Question about Hitachi Cameras
I have a Hitachi Camera HDC 1087E, using camera on holiday sudden says card error and now does not work. Why?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 25, 2010
Hitachi HDC-I49IEP how to delete pictures
Try formatting the card using the option in the camera itself. or take the card out and put in laptop / PC using the card reader and try formatting the card.
Apr 13, 2014 | Hitachi Cameras
Can anyone help please i have a Hitachi Digital Camera HDC - 761E and all of a sudden i cannot pick it up on my computor to download pictures
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 14, 2012 | Cameras
I need a download manual for Hitachi HDC-1087E
You may download a copy of the manual from here.
Sep 13, 2012 | Cameras
Can i download software for my hitachi hdc-1296er
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program, such as Picasa.
Apr 03, 2012 | Hitachi Cameras
My hitachi hdc-991e camera turns itself off after i take photos
It's bad/weak batteries. I had the same problem using Hyundai batteries, thought the camera had broken until I used Duracel instead and it worked as it should. Batteries don't last long in digital cameras full stop, but decent brands like Duracel will help.
Jun 25, 2010 | Hitachi i.mega HDC-401 Digital Camera
How do i transfer photos from sd card to camera on my hitachi hdc 651e
1.Remove your SD card from the camera.
2.Insert it to your laptop card hole
3.If a window opens opens automatically then just drag and drop your photos to where you can find easily.
4.If a window does not open then click to My Computer
5. Find your SD card there.
6. Do the instruction number 3.
That is all.
Apr 02, 2010 | Hitachi i.mega HDC-401 Digital Camera
L took some pictures last night and then decided to put some into black and white. l pressed the format option and all of a sudden all the pictures disappeared. the camera is a hitachi hdc 86IE or is it...
yea i got the same camerA
i just tried that now you know foormatting it and it says *NO IMAGE*
i think you should next time just get your photo put on the computer anduse fotoflexer.com (trust me ive used this site before
Jan 24, 2009 | Hitachi i.mega HDC-401 Digital Camera
Cameras Logo
112 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
