Question about Canon CFX-L4000 Plain Paper Laser Fax
Need to fax and get proof of receite that fax was sent - How to set up fax for confirmation of recieved fax
    President:
  • 566 Answers
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
Posted on Oct 17, 2010
  • kkkkkevin Jun 06, 2011
    The link no longer works, where else can we find the manual...I don't get a reeite that the fax was sent either.
  • A Soveral Jun 11, 2011
    Here is a link to Diplodocs.com from where from where you can dowload the manual:http://manual-de-instrucoes.com/414159.p... CFX-L4000
    Just copy the numbers that appear in lthe left box to the box in the right and click the button underneath to download. Save a copy of the file to your computer
    And here is a a temporary link to the same file:http://dl.dropbox.com/u/1322442/CANON%20...
I cannot figure out how to get a confirmation receit showing my fax was actually sent. How do I do this? Thank you.
You need to turn on report printing in order to get a confirmation page that shows your fax was sent. to change the settings you press the menu key and then use the arrows to navagate the choices until you see fax set up. Then you press "ok" or "enter". Then use the arrow keys again to scroll the choices until you find reports or confirmations, and then again press ok or enter. Then use the arrow keys to change the reports that print when a fax is sent and save your changes by hitting ok or enter. Then try a test fax to make sure the report prints and your done!
Jun 13, 2011 | Epson Office Equipment & Supplies
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Confirmation page needed
Press MENU - 2 4 1 then you can choose to have that feature ON or OFF. the +Image means that it will also print a copy of the first page sent so you can actually verify the document sent.
Mar 31, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
We are not receiving faxes..we keep getting error code 407..Please help? Thank you.
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
Mar 16, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
Unable to recieved any faxes or confirmation reports
Probably the back up battery is dead, and has been set back to default settings.
I can't help you with the method of setting, but it has switched to "manual receive", instead of "automatic", and "tx report" (transmission report) is off.
....and "no" you can't install a new battery yourself, and depending on the model, I doubt it's worth having repaired
Apr 02, 2009 | NEC Office Equipment & Supplies
Faxing
you can see job confirmations under job list, there you see, whats ok and whats not. also paper format you can choose under fax sending screen, before sending fax. probably you caan choose a default page format from utility - user/ admin settings
Apr 17, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
BROTHER FAX/TELEPONE T76
Unplug and plug back in see if that gets rid of the check paper pls open top cover. Also make sure the confirmation is set. Transmission report on
Oct 31, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon CFX-L4000 Plain Paper Laser Fax Logo
156 people viewed this question
old marine
old marine
