Question about Music
Where can i get a replacement 1501 bass speaker for my unit at a cheap price or can i use anotherf speaker in it
  • Music Master
  • 5,603 Answers
We can only guess what device you need the speaker for as there is no brand mentioned in you posting.
There are speaker suppliers on Ebay that are fair priced. DO CHECK dimensions as they vary and may not quite fit your unit.
Many of the bass amps use Celestion speakers and depending on the size the price varies. DON'T be to cheap on speakers as they may not hold up and you get to listen to them for a while!
Posted on Aug 25, 2010
What is the modern replacement speaker for Marshall 27115 bass combo
You would be Seamus?
Eminence are not a high-priced speaker. You could replace it with one of the bass guitar speakers here, like the large magnet CB15
http://www.usspeaker.com/15.htm
Sep 26, 2016 | Bass Music
Where can I buy a replacement speaker for the Crate B100 bass amp? Someone took a screwdriver to the paper part of the speaker before I bought it at a pawn shop
The most reasonable place for a new speaker is Seismic Audio https://www.seismicaudiospeakers.com. If you don't care for that, look for an Eminence Delta series. You'll need to check your amp for what ohm speaker you need.
Jan 31, 2015 | Bass Music
How to replace a defective speaker on the Casio CT-638 tone bank keyboard
Hi, Yes it can be fixed.
It may not need fixing, It may have just worked loose. If it is faulty then any general purpose speaker that will fit will be OK. Consider replacing both if the replacement is radically different.
Speakers can be as cheap as a few pounds.
Paying someone to do the repair is something else. It will take longer to take the keyboard apart than affect the repair.
Consider buying a replacement from eBay, second hand, and get a competent amateur to repair yours!!
Failing that, use the headphone out (which cuts the internal speakers) into a hi fi or external instrument amp.
Good luck, Chris the Fader.
May 21, 2014 | Casio Ctk-5000 Electronic Keyboard Piano...
Speakers specifications
ES 315 is 200W RMS
60-15KHz but not sure if this is -10db or -3db as it doesn't say
15in heavy duty bass driver, 8in specially designed mid range and 4in tweeter.
34.5Kg 730mm x 620mm x 375mm
These are a very old design and not very efficient and you probably would get better value from a cheap new pair.
Feb 04, 2014 | Behringer Music
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
One of my MR8's has only its tweeter working, im guessing the bass driver might be blown? How can i test this though and be sure it is the bass driver and not just a simple electrical fault?
Open the unit and remove one wire from one of the woofer terminals and using an ohmmeter check the resistance between the terminals. It probably should be between 6 and 16 ohms... they don't give the specs on the speaker... if it is very high or infinite resistance, the voice coil is blown and you be re-coning or buying new speaker. These are close in speakers and intended for a small room for studio listening while mixing. If the speaker is OK, then the bass amp in the cabinet has a failure... pray, as that is cheaper to repair than a speaker.
Sep 22, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
After working great for over a year my speaker seems to only have treble with no base. Not sure what to do
This is a bi-amped speaker. That means it has a separate power amplifier driving the bass woofer and treble horn. They have a low-level electronic crossover to separate the frequencies to the appropriate speaker. The electronic crossover is the least likely to fail... so you need to do a test:
You will need to open the unit and using an ohmmeter check if the woofer speaker voice coil is open or has continuity...It should be around 6 to 16 ohms. If it is above that, the speaker itself is blown and will have to be replaced. If the speaker has continuity, then the bass amp has failed and will require repairing by person that is adept at electronic repair. Before opening the unit you MIGHT be able to diagnose whether the speaker itself is blown by seeing if the woofer generates a thump when power is turned on or off. If it does, then likely the speaker is OK and the problem is the amp, otherwise the tests above need to be done. Usually these plastic cabinets are held together with seveal scrwes from the back. Some are in :deep "wells" and will require a very long shaft phillips screwdriver... and they often are long screws that wear one out unscrewing them. A genlte pry after removing the screws will separate the back and the front.
Jul 16, 2011 | Samson Auro D412A Speaker PA Active
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Sep 21, 2010 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
My son's guitar amp Epiphone guitar amplifier model ep-800, does not work after someone plugged a bass guitar on high settings. He tried it the next day, only to find out it didn't work. Could the bass...
it could have blown the speaker, a regular guitar amp is not meant to handle a bass, you should be able to look into the back of the amp and see if any of the speaker is damaged, or there may be a blown fuse inside the amp, if you check for this please MAKE SURE TO UNPLUG THE AMP FROM THE POWER SOURCE FIRST, and if needed replace the fuse with the exact same type
Mar 21, 2009 | Music
Music Logo
19 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
