Question about Refrigerators
Why my fridge keeps icing up while the freezer is ok
  • 4,793 Answers
Generally speaking the fridge is not frost free whilst the freezer is.you can reduce the amount of frost by checking door seals are tight to frame/drains are clean and free of s..t and ensuring food/drink is covered to cut down on condensation.if you have a seperate thermostat set it to +5C.
Posted on Aug 25, 2010
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Hotpoint RZA30 Future Freezer keeps icing up. needs defrosting every month
freezer can over ice when not enough air is curculating to the back of the unit, if you have a very warm or hot kitchen the curculation on your freezer over ices the contence because of lack of air getting to the pump, the grinding noise could be the pump working overtime trying to gather air. also check the back where the tank is to made sure nothings been damaged ie - kinked in pipes.
Mar 09, 2012 | Refrigerators
Fridge walls very warm around freezer door
that is ok these fridges have the condencer lines within the walls of the fridge or some have heaters this is for condensate not to form on the fridge it keeps the fridge dry on the outside
Sep 26, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Our freezer and fridge or not keeping cold enough
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor or back of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Jul 15, 2009 | Refrigerators
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
