Question about Acer Aspire One PC Notebook
Acer Aspire One, the Laptop powers on,the yellow light comes on when you hit the power button, thats about it you dont hear the hard drive running and the lcd dosent come up either,sometimes if i remove the battery then reconnect it then it will boot up, same thing if i unplug then reconnect the power adapter.if it boots up and i shut it down when i power it back up again it dosent boot, ill have to hold down the power button for a few seconds for it to tun off then unplug the adapter then reconnect it then hit the power button then it boots up.
  • Acer Master
  • 629 Answers
Sounds like a power issue, may be related to the motherboard and you may need to get in touch with Acer support for it, but try these and see if it helps. turn off the system, remove the battery and adapter and remove the hard drive and memory if you can. with the components removed, hold down the power button for about 10 secs to discharge whatever power remaining. After that, connect all components, boot in BIOS and reset the default settings, and then restart the computer and observe it. Make sure to set any BIOS options again that you may have set previously.
Posted on Aug 25, 2010
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
If the computers lights are just yellow what does that mean?
Just Yellow when? Tell us what happens time you put the power cord in and press the power button? Does it try to boot? Do the lights blink? Hear any beeps? Hear any fans? Does anything ever appear on the screen?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge. Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Acer Aspire 5500 5570-2609 Laptop
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
The cmos on my laptop(acer aspire 5536) was wiped and when i turned it on it wouldnt boot up just blank screen and a fan still works plus the power button still glows and the little yellow and blue lights...
yellow light indicates that it is offline mode/ log off/ power save mode/ hard reset by pressing power button for 10 sec and restart machine in safe mode that it could solve any h/w related problem
May 30, 2011 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire one notebook wont work! Help!
First off, does it power on....does the power on light show on the laptop when it is plugged into the wall outlet. If it does power on, do you hear the fan running and the hard drive clicking? Can you see if the hard drive indicator lights are active, they will be next to the power activity light. If you cannot see any lights at all, try another charger, the one you have may be faulty. If you can see a power light, but the laptop wont power on, then you very well have a motherboard issue...or your ac adapter is not putting out enough volts to actually power the system completely. Check power first, then think motherboard issue. You don't have to have a good battery in it if you are plugged into the wall outlet.
Aug 30, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
Problem Bringing up Acer Aspire 3680
Hi i think the problem is with the battery or power supply.When you power up the laptop without the external keyboard and mouse everything is ok, yes?Check that the battery is charging properly and that the charger is doing its job.
Dec 24, 2008 | Acer Aspire 3680 Laptop
Power ON/ nothing on screen-
enter the bios setup, if you can boot the computer/laptop. Usually F2 on bootup, it will say entering Setup.
Then scroll through the pages to see if your hard-drive is recognised by the system.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Acer Aspire One  PC Notebook Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
