Question about Dayton (3E379) Heater
Dayton 3E372B Fuel Trimmer
My heater kicks on, pilot ignites and fan turns on, however all of a sudden the gas lines go out and everything ignites again. This process keeps repeating over and over. The module is operational, the thermostat is working and the blocked vent switch is new.Any ideas would be helpful.
    New Friend:
  • 70 Answers
Sounds like the thermal couple could also be the ignition module.Is it spark ignition or hot surface
Posted on May 06, 2008
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Furnace will kick on, begin heat up, go to the point where the fan should start and the whole thing shut down. If I move the thermostat down below the temp it show, it will start again and do the same...
Sounds like the blower motor is bad and then the unit is kicking off on high limit....
Probably nothing you can do with out getting a new motor to replace the bad one...
Feb 02, 2011 | Dayton Gas Furnace Heater
I have a dayton 3e372b gas heater. it comes on when stat calls but flames stay low and blue, its not giving enough heat. is this my control valve maybe not working properly???
could be the reg on the gas line at the meter , is there gas to the rest of the house , check pressure at meter , and at the heater first .
Dec 09, 2010 | Dayton Gas Furnace Heater
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
I am having a problem with a dayton(3E229D) gas heater. It has a standalone pilot that is lit and stays lit. The problem is that the burners don't ignite. I turn the heat on at the thermostat the fan comes...
if you can use a meter check for 24 volts at the valve when you call for heat. If you have 24 volts and no burners then the valve is bad, if you do not have 24 volts then another safety is locking out the valve
Dec 11, 2009 | Dayton Gas Furnace Heater
I have a dayton fuel trimmer garage heater. The pilot will light, but the main burners will not ignite. Could it be a faulty gas valve?
if it has a power phile on it then you would get pilot and no gas , change the power phile if this is the case ,
hope this helps
Dec 07, 2008 | Heating & Cooling
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
Dayton (3E379) Heater Logo
335 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
