Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner leaks water in side the room. after the drain hose was change and clamped.
I had the same problem. The insulation on the coper line was loose and the pipe was exposed. The water was condensation , not water from the drain.
Posted on Aug 28, 2010
Can you operate an amcoraire duo UCHW-H12AF2 without a remote control?
The unit will run @ 75 degrees without the remote. Go to Ebay.com
Search Amcoraire Remote Control, you will find what you need.
Jun 24, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Replacement parts Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner
Amcoraire USA went bankrupt in 2010. Bought out by Pridiom group. Service Dept 1-201-266-8234 or 1-201-562-9777
Jan 25, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
AmcoireAire UCHW-H12AF2 ;the scrin show me F1
the F-1 error code is reserved for the inverter systems made by Amcor. What model do you have ?
Support@Pridiom.com
Sep 05, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
At AmcorAire Conditioner the circut panel has burned. How I can replace it?
We stock a complete line of parts for the Amcor Mini Split Systems.
Support@Pridiom.com
201-266-8234 option2
Jul 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Low cool air
Because the model numbers are based on the country in which you bought the unit, you will have to do the research yourself on the error code for your unit. Once you find out what the error code is you can determine if low refrigerant caused the problem. Here is the contact info website to download your manual.
http://www.amcoraire.com/index.html
Apr 03, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
140 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
