Question about Microsoft Windows XP Home Edition
All programs or applications when are clicked to run or open their is an error messages like in which this program is to be open with where else it is .exe application which should start itself.For instance,if i want to set the desktop to refresh an error message comes as Windows cannot open the application for rundll.exe not found.Overall i mean to say any program nor opens or runs directly by click of mouse..
  • 104 Answers
Get rundll.exe from net and paste to window32 in local drive c
Posted on Aug 25, 2010
Run-time error 339 - OS: Windows 7
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Runtime errors Some applications may be causing a conflict. Many times runtime errors are a result of incompatibility between two or more programs. Press the "Ctrl," "Alt" and "Delete" keys simultaneously to open Windows Task Manager. From the "Applications" tab, close each open application until the runtime error is resolved. Check for patches, bug fixes or upgrades by visiting the manufacturer's website. Search for your product and determine whether there are downloads to fix the problem your PC is experiencing. When none of the above fixes help, reinstall the troubling program. In severe cases, you may need to reinstall your operating system. Make sure that you back up the other programs and files you want to preserve, which may be erased during the re-installation. Hope this helps.
Jan 10, 2013 | Microsoft Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
Close the other video streaming application to start video
Your camera is already online. Double click the camera icon in the lower right task bar and it will work. That is the problem, the program is trying to run twice. Again, the camera is online and working and the access to it is in the task bar at the bottom. You, of course, can change these setting if you like.
Jun 21, 2009 | Dell Studio 1737 Laptop
3 software packages won't install or run.
TRY,, DRIVER MAX free program i always had problems with driver detevtive
May 22, 2009 | HP Pavilion m7480n (882780389410) PC...
When I turn my computer on, I get a runtime error.
Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
System won't open programs and files
hi. its purely a virus problem that prompts u from performing some actions in ur system. visit filehippo.com website. download AVG anti virus latest version scan ur computer. the problem wil get solved.
Jan 20, 2009 | Toshiba Satellite A105 Notebook
Referenced memory error in photoshop elements 6
Was it the preferences file that you deleted? The description you gave to your problem sounds like your running a windows machine instead of Mac so i'll give you keys for PC. While program is launching hold down the following keys "Control+Shift+Alt" then when there is a screen that asks to delete the prefs files select "yes".
Nov 16, 2008 | Adobe Photoshop 7.0 for PC
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
Jun 17, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Microsoft Windows XP Home Edition Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
