Question about Cnet CNP 430 (CNP430) Print Server
My cnet cnp430 print server wont print from Unix. It works fine on the windows side
  • 724 Answers
Unix needs to have a print driver too
Posted on Aug 26, 2010
Run a cnet cnp430 on windows 7
I hope you are connecting the print server to a network hub or switch and not trying to connect directly to your Win 7 machine.
There are no drivers, a print server is a network device. Connect the ethernet cable from print server to your router. connect your printer to the switch. Search the network for the printer.
Apr 06, 2014 | Cnet CNP 430 (CNP430) Print Server
The logic card of my TallyGenicom 6312L line printer has been repaired. it is not working on Unix OS but working in Windows envirinment. what is the solution?
The solution depends very much on the cause of the problem. I note that you can print from Windows, this indicates the intrface you are using is functioning correctly and it should therefor be possible to print from Unix to the same interface if it is connected to the Unix system. If the printer is connected via a network interface, check the IP address on the printer to ensure it matches the IP address set up for the Unix print queue. Try pinging the printer from Unix. Ensure the EMULATION setting on the printer matches the Device Type selected on Unix. You may need to identify if any data is being sent for Unix perhaps try sending a test text file to the printer. A common cause for printers not printing from Unix is no Carriage Returns or Line Feed commands in the data. Try setting Auto CR to ON in the printer, of this does not work try setting Auto LF to on. If there is still a problem please post the connection method and also any errors or symptoms seen when printing from Unix
Sep 27, 2011 | TallyGenicom 6312 Matrix Printer
Sir, We have a Genicom 6312 L Line Printer. This printer is attached with UNIX (5.9) system. It was working fine till few days back. Recently we changed the Logic Card. After this the printer is not...
If the printer does not print from Unix via parallel interface, it may be nessesaey to set the BI-DIRECTIONAL setting within the Parallel interface settings to OFF.
Sep 21, 2011 | TallyGenicom 6312 Matrix Printer
Print jobs get stuck in the queue
OK - all the answer posts on HP sites, Experts Exchange and MS have been a joke to this problem so far. HP 10xx series LaserJet printers do not work (well) in a shared environment. I have found two solutions to this problem. If you really don't understand shares/printing/services/firewall exceptions - don't bother trying this - buy a networked printer when the toner runs out of the HP10xx.
If you want to spend a few hours or about $100 for a print server/NAS device, read on... I HAVE an HP1022 shared on a Windows XP Pro SP3 machine serving as a print server to a Vista laptop, a Windows 7 desktop and a Mac-Mini running OS X 10.6.x. ALL are working.
1. Buy a network print server device (or a NAS device with an included print server - I picked up a Buffalo LS-CHL 1TB and it worked out of the box. I AM NOT ENDORSING BUFFALO NAS servers, they get horrible reviews and you may end up having the same problem down the road due to the NAS device) In this case, your print clients (Win7, Vista, XP, MacOS X) can use a traditional SMB Windows client to print or the BETTER solution is to use the print services for Unix client that comes with Windows but is not installed by default. Both clients work, you may have fewer problems down the road using the Unix (LPR) client. See http://www.alexfalkenberg.com/2009/10/06/linkstation-windows-printing-problem-solved/ This is an excellent article on the Buffalo - BUT THE SOLUTION works in a native windows environment as well.
2. Build on the idea from number 1 above and INSTALL the LPDSVC (friendly name TCP/IP print services) on the machine with the printer LOCALLY attached through USB. You will also have to open up some firewall ports on the machine you are using as a print server if you have one running... I used a program exception (C:\WINDOWS\system32\tcpsvcs.exe) but you could lock this down to 1 TCP port if you wish - I think TCP 515 but you'd better check on this one...) Share the printer as normal. Next install the "Print Services for Unix" CLIENT on the machines you want to connect to the printer remotely from. When you connect to the printer share from the clients, select a LOCAL port, create a NEW PORT, select LPR, use the hostname or the IP of your machine acting as a print server and the NAME OF THE SHARE as the queue. (I don't like to have spaces in my share names, so I used HPLaserJet when I set up the share and description.) You will HAVE TO INSTALL THE RIGHT Printer driver locally on each client. This might be easiest just plugging in the printer with a USB cable since the HP printer driver is an installer as well and wants it to be connected locally unless you can extract the driver...)
Sorry I can't give more details than this. If you don't get the jist of what I am saying above. Don't try it. Give up and call the plumber.
Feb 09, 2010 | HP Hewlett Packard LaserJet 1022 Printer
My WGPS606 wont print on my Windows Vista laptop, its prints with all normall xp windows laptops and desktops, but I recently bought a new laptop and it does not print, the print says error, can somebody...
there is a proceedure for manually adding the printer ports instead of using the wizard on the software disk. Look on the disk and go to the guide .pdf file, the instrucitons are there. i tried it and it worked fine.
Apr 01, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Reset factory setting
Try consulting the manual for the printer:
http://www.retrevo.com/support/CNet-CNP-430-manual/id/8366bh135/t/2/
Dec 18, 2008 | Cnet CNP 430 (CNP430) Print Server
Dp-g321 does it work with vista
According to its Datasheet, it will only work with the following Operating Systems:
- Windows 98, ME, 2000, XP
- MacOS EtherTalk
- Unix
- NetWare 5.0 or above (Native NDS)
- lpd
You can go to this link to download its Datasheet.
ftp://files.dlink.com.au/products/DP-G321/Datasheet/DP-G321_datasheet_01.pdf
Sep 13, 2008 | D-Link DP-G321 Print Server
Configure D-link DP-310P by using Unix
You need to use the LP service /etc/init.d/lpd in UNIX and you need to set up the printer definition. Use the man page "man lpd" and it will tell you how to configure it. The kind of driver you use will depend on the kind of printer. Eg., is it an HP Laserjet compatible or a Postscript compatible. That affects the kind of "language" lpd will use to talk to the printer. Setting up LPD can be fairly complex.
Another avenue is using CUPS which is a much better print server solution. You can read the man page by typing "man cups" or "man cupsd".
Good luck,
David
http://www.tekops.com
Mar 04, 2008 | D-Link Express EtherNetwork DP-301P+ Print...
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Cnet CNP 430 (CNP430) Print Server Logo
85 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
valuesrespec
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
