Question about Nelson Sprinkler: Traveling Tractor
I need to order two new rotating arms for my Nelson Water Tractor. The arms are aluminum I assume, and are about 3/8" diameter and are slightly bent 4" or so at the end of the arm to allow them to rotate and spin fast when the water is on. Do you have them in stock? What is the cost? Can they ship today? I need them delivered to me by Friday, August 27th.
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Nelson Sprinkler Rain Train Traveling Sprinkler will only go backwards , i have the arms going in the right direction...please help
If it's going backwards, and assuming you didn't take it apart and put it together wrong, then the arms aren't going in the right direction. Looking down from the top, my unit should be moving clockwise if it's set up correctly. In any case, switch it so the water pushes the arms in the other direction. the transmission is pretty straightforward - if it's going in the wrong direction then the arms are spinning in the wrong direction.
Aug 02, 2011 | Nelson Sprinkler: Traveling Tractor
The traviler goes backward remmedy please help
Hi, loosen the spray arms and rotate them opposite to the way they are laying now so when spinning the arms rotate clockwise. Hope this helps, regards Phil.
Jul 28, 2011 | Nelson Sprinkler: Traveling Tractor
My tractor sprinkler was running fine and then suddenly stopped. What should I look for as the problem?
My sprinkler did (something like) this a couple of times (very infrequently) - the arms seemed "seized" (cannot rotate clockwise or counter clockwise) but, I was able to get them moving again by picking up the sprinkler (a couple of inches) by the sprinkler arm T-pipe. Picking it up this way, vertically, seemed to "un-stick" the arms.
Of course, if your sprinkler is very old (12 years?) the gear box may be worn, it would cost about a quarter to a third as much as a brand new sprinkler to replace. You can find the parts you need by reading the question about where to get parts at FixYa.
Jul 02, 2011 | Nelson Sprinkler: Traveling Tractor
I have a Nelson traveling tractor for at least 12 years, now. No problem until this week. While traveling tractor was watering yard it turned over in some softer sand - which it has done previously - and...
I think that you need a new gear box. Your unit is 12 years old and the valve inside (the box) probably became separated from the "button" you pull down. Getting a new valve would solve your problem but, it would have to be installed inside the gear box. Since the gears may be worn (after 12 years) - I recommend a new gear box. This would solve your problem and prevent future "worn out" problems. This also saves you assembly of small parts.
Jun 23, 2011 | Nelson Sprinkler: Traveling Tractor
My son tipped our neighbors tractor sprinkler over and broke the plastic valve piece that holds the arms. Any way I can get that valve? Has three holes one from the bottom and the two for the sprinker...
You have to buy a arm kit from Nelson or one of their vendors. You get 2 new tubes & the plastic tee that goes in the center of the motor. There around $15.00
Jun 16, 2011 | Nelson Sprinkler: Traveling Tractor
The watering arms won't turn to move the tractor
Check your water pressure... you need to have 40-60 PSI.
heatman101
Nov 17, 2010 | Nelson Sprinkler: Traveling Tractor
Need tractor parts
I found this Nelson website to be the best. Good luck! http://www.lrnelson.com/products/files/1865_2001C.pdf
Jul 20, 2009 | Nelson Sprinkler: Traveling Tractor
Need replacement nozzle for the rotating arm
I found parts for the Nelson traveling sprinkler on ebay.
Jul 19, 2009 | Nelson Sprinkler: Traveling Tractor
Nelson Sprinkler:  Traveling Tractor Logo
124 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
