Question about Carrier 38CKC036 Air Conditioner
The plenum that houses my coils sweated repeatedly and the coils seemed to freeze. An agent told me that my unit was leaking at the fittings to the outside unit as well as the coils . The unit he used to detect the leak beeped almost all the time including when he wasn't sniffing at the sites. The evaporative coils and the AC unit are 6 years old . How likely is it that the coils are really leaking?
  • 455 Answers
Hello JBESTER Defrost the unit completely and see if the pressures are low.If more than half the charge/freon(3+)lbs has to be added you have a leak.Make sure the air filters are new as poor air flow can cause ice also.The sniffer I use beeps all the time BUT when near a leak goes crazy!The coil can leak after 6 yrs.You will always will need a recharge untill leak is resloved.
Posted on Aug 25, 2010
Chest freezer
check that the drain plug is tight in the bottom
go back to the retailer and ask for a warranty refund as chest freezes do not " sweat"
the machine is not fit for the purpose
talk with a lawyer if you have to
Jul 02, 2017 | Frigidaire FRS26ZSG
Leaking intake plenum
I doubt a leaking plenum would cause it not to start. Usually a leaking plenum would cause an air leak and make the engine run too fast.
Any trouble codes stored ? Will it start using carb cleaner spray ?
Jun 25, 2013 | 1995 Pontiac Bonneville
I have a new 5 ton Grand Aire A/C. It seems to take much longer to cycle than my old unit did. Also my plenum is sweating in my attic? Is this normal? Any Suggestions?
sounds like poor airflow if unit is same size as old equipment and duct work is sized correctly you can try raising fan speed if using a pleated type 90 day filter switch to fiberglass non-pleated type filter that restricts less airflow. Also check return air for leaks you could be introducing unfiltered hot air from attic or enterior walls.
Aug 29, 2012 | Whirlpool Heating & Cooling
I bought a new Goodman heat pump in jan 2010. It has a 2 1/2 ton compressor with a 3 ton A- coil. I was told by them this would work fine with an expansion valve.`I have had nothing but problem since...
The "A" coil will generally be larger than the outside coil as far as the tonnage goes. When a unit has an expansion valve the charge should be based on subcooling instead of superheat. The reason for this is that the expansion valve acts to maintain a constant level of superheat. The best solution may be to have all the refrigerant recovered, then weighed back into the system. The length of lineset should also be checked. Units come precharged with enough for 25' of lineset and the charge will need to be adjusted for more or less that 25'.
Dec 11, 2010 | Heating & Cooling
We had 2 new units installed 2 yrs ago and now it's sweating
1st of all the pan under your unit should not have water in it unless the primary drain from the evaporator coil is plugged.
2nd the secondrary drain pan underneath the unit should go to some kind of drain, along with the drain
from the evaporator coil. They should not be hooked
together until they reach the proper drain.
Check to see if they are hooked up together, if one is
plugged the other one will be to. The drain line could
be to small as well, check to see if they ran the condensate drain in 3/4inch pvc pipe or hose minimum.
It could very well be that they did not insulate the plenum, if it is sweating on the outside, insulate it.
Jun 28, 2010 | Heating & Cooling
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
Brunt smell and sweating
Seems like your blower motor is burning up. Its the motor that blows cool air across the refrigeration coil. If it is a whole house ac unit, probably your main blower motor for the furnace. If you are getting sweat, that means the compressor is compressing the refrigerant, and you should not smell anything from the outdoor unit, only from the furnace. Hope this helps.
Jun 04, 2009 | Goodman CKL24AR24 Air Conditioner
Coil freezes up
Usually when the indoor coil freezes up you either have dirty filters or coil but if you had this unit replaced last year your coil and filters are probably OK so you probably have a leak in the unit and are low on refrigerant.
Apr 24, 2009 | Heating & Cooling
My central air unit keeps freezing up on the inside
1) locate the A-Coil (A-frame) inside the furnace. It is usually located in the furnace supply plenum located on the "down" side of the furnace plenum. If it is very dirty, there will be poor air flow generally in the house. This can cause the A/C to "freeze up" as the refrigerant is not getting enough heat to convert the refrigerant to a gaseous state.
2) The unit may be low on freon (or whatever refrigerant you are using). Contact a serviceman to check the unit.
Jul 07, 2008 | Coleman Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
