That is the thing. I know for a fact that my current CRT is working fine. It rand beautifully on my computer back home. I have a suspicion that it is something related to the actual computer/video card rather than the monitor.
  • mrmagoo86 May 05, 2008
    This post is relating to a previous post concerning ghost shadows of my display on windows xp with an old nvidia vanta.
    screenshot shows the situation:
  • mrmagoo86 May 09, 2008
    The problem is not with the monitor(s). I have tried 3 different CRT monitors with this one particular tower. I am very convinced that it might be a graphics card flaw. Anyone have some ideas as to what, in a gpu, could cause this?
  • 558 Answers
I have this issue on a proview 17 inch lcd it is a issue you either live with or get another monitor, shutting it off for 8 hours does help mine.
Posted on May 08, 2008
  • Scott Hill
    Scott Hill May 28, 2008
    if you have tried 3 crt's and get the same issue then replace the video card............
I have Samsung DVD home theater system model ht-d300k it went of nd never turned on ever again what might be the problem there nd how to fix it?
what do you mean "went of nd"? Not knowing what that means, I will tell you that after many years of dealing with all sorts of electronics, the first thing to do in your situation is to unplug the unit or units, wait about 3-5 minutes, plug them back in and try to turn them on. Sometimes, things just need to "reset". On the other hand, it may do nothing, but that is the first step. I've run into this again and again with TiVo, and it works more often than not. Good luck.
Jul 27, 2016 | Samsung Audio Players & Recorders
I was charging it nd it was chrage nd out of no where it turn off nd never turn back on nd it doesnt chrage no more
Hold the power button and the home button down at the same time for 20 seconds. if it still doesn't power on, try to put it into DFU mode and plug it into iTunes to restore it:
1. Hold the power button and home button for 10 seconds.
2. Let go of the power button and continue holding the power button.
(http://www.iclarified.com/entry/index.php?enid=1034)
Mar 01, 2011 | Apple iPod touch 1st Generation (8 GB) MP3...
My home network was working fine for a long time. Here's the config: cable modem > main PC > Tu2-ET100 > xover cable > TU2-ET100 > second PC. I can connect PC to PC fine, Internet on main...
if one computer is working and the second one hooked on it not than it may be a cable thing ..if both are not working than it is a network and you have to call the provider...to check that plug them one by one directly to the main cable ..cause there is a possibility the the main ones LAN card to failed ..and cause both are basically connected trough it they can not work ..
Usually most computers have a on board LAN port ...if it is a suspicion that the LAN card failed try to use the one on board ..
Sep 02, 2010 | Trendware TRENDnet TU2 ET100 network...
Monitor fine with 1 PC, no RGB input after windows load on other?
Lower the resolution on the computer to 800 x 600 and then hook up that monitor see if it at least accepts that and doesn't go black. You may have to go into safe mode to do it plus then go back into regular mode.
May 07, 2010 | HP mx705 17" CRT Monitor
My computer monitor has switched off when it is switched on?
check the wire nd vga port if its not working then remove ram nd rub it with eraser
Aug 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
DVI won't work
WOW! I have that monitor too on one of my systems!
Strange thing is it HATES the SVGA connection ~ but works FINE with the DVI... wish I could tell you why?
I've tried a array of 'new drivers' but none help... STRANGE thing too is OTHER monitors work FINE (with the VGA port) so I'm fairly confident it's not that...
I CAREFULLY inspected the pins on the male connectors to assure none are pushed back into the connector body and tried new cables too... still NO GO?
PLEASE let US know if you found a solution!
Anthony
Dec 12, 2017 | Samsung SyncMaster 214T Monitor
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
Screen flickers
ram problem once clean the ram and insert it again if the problem occurs again the change ur ram it will rectifye ur problem
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
Computers & Internet Logo
405 people viewed this question
David Payne
David Payne
