Question about Sirius Satellite Radio Receiver
I have a ORBITER, SR4000 receiver, and it continues to search for signal. Sometimes it will show the display and play, but most 9 out of 10 time it is in the search for signal mode. I've tapped on the rcvr, and sometimes it will start playing, but only for a short time. Sounds like I might have cold solder joint. I also have a lifetime membership.
3 Suggested Answers
SOURCE: Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Posted on Jun 06, 2009
  • 65 Answers
SOURCE: my radio wont play anymore. think it is because i
do what I did..call Sirius and tell them you want to cancel your subscription because your radio broke.They should send you a new one for no charge...it won't be same model of radio but at least they will replace it.The last thing they want is to lose a subscriber.also make sure you talk to an American operator.they outsource their operator business to some third world country.If you ask them,they will connect you to someone from USA. I hope this helped.I'm actually speaking from experience.theyve already sent me two replacemnt radios for no charge.Good luck
Posted on Jan 17, 2010
How do I change to daylight saving time?
Your clock may have failed in a way that new batteries won't help.
Apr 04, 2015 | La Crosse Technology Atomic Wall Clock -...
Startrak 950 orbit treadmill
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Jun 03, 2013 | Nautilus Exercise & Fitness
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
On my bosch wfvc5400 dryer, i need to stop the beeping! Help!!
Welcome to FixYa.
To change the volume or disable the signal for the WFVC dryer is as follows...
Press the Menu button to scroll through options to "Signal setup". While in "Signal setup", press and hold the Select button to continuously change the signal volume. While changing the volume continuously, the display will show "Continuous" - when the maximum volume has been reached, the display will show "Max".
Hope that answers your question. Good luck and thank you for choosing FixYa today.
Please take a moment to rate the assistance you received today positively and a brief testimony is always appreciated.
Regards,
Macmarkus :)
Apr 20, 2011 | Kitchen Ranges
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
I have been having issues with the receiver "losing" the signal or interupting the signal from my blu-ray player and previously when using a dvd player. the DVD continues to run and when the...
That's one of several reasons I can think of to bypass the receiver's handling of any video I care about. I only let my receiver 'see' the audio from anything external and send it's own video to the TV so I can see its internal menus.
I don't know what can be done if your video-carrying cables are all good.
Jan 01, 2011 | Onkyo TX-SR706 Receiver
Inverted NOKIA display
Its not a thing may heppend by playing only (but is possible) it may be dropped on the ground or something like this and display commection to main board has troubled (some connections is disabled) ans when display receiving damagd signal it shows up incorrect picture. sometimes may correct picture but better way is to take it to customer care, because phones don't have such functions and correction by yourself is quite difficult bussiness.
Jan 23, 2010 | Nokia 3100
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Sep 05, 2009 | DISH Network DVR-625 DTV Receiver /...
Phillips Mp3 player-Songs get cut-off half-way through playing
Play this file in media player 9,10.if it play fine then the problem of mp3
Feb 29, 2008 | Philips GoGear SA178 MP3 Player
Sirius Satellite Radio Receiver Logo
108 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
