Question about Brother HL 2140 Laser Printer
How do i clean the corona wire for my hl-2140 printer?
    President:
  • 548 Answers
Well the best solution for the corona wire is to change it. It is the best and safest solution.
If you need further details and assistance please leave a comment. Cheers
Posted on Aug 26, 2010
How can I replace the corona wire in the drum of brother HL 2140 printer, I've seen it broken, I'd disassemble the assembly and two terminal lugs w/ broken corona wire dislocated to its position.
Hi, I have the same printer as you. My background is in the development, design and manufacturing of printers. while i didn't have the opportunity of designing the toner system, I do know that doing anything with the corna wire requires that you never touch the wire with your bare hands.Replace the corna wire requires special tools to set the tightness keeping clean in the process. Unfortunately by the time you spend to replace the wire, it would be easier to buy a replacement drum. there are some reasonable cost rebuilt drums sub systems. look on ebay to find them.
Jan 31, 2015 | Brother HL 2140 Laser Printer
My printer HP ( HL-2140 laser ) print out a black sheet?
This will be the Corona Wire on the drum has broken. Replace the Corona Wire if you are technically minded or replace the drum unit if you are not.
Jan 10, 2015 | Brother HL 2140 Laser Printer
HL-2140 Clean Corona wire Message won't go away.
you have to take out the drum and on top of the drum unit, there is a blue color plastic which can be slide from left to right... just slide a few times from left to right...that will clean the corona wire .
Jun 15, 2010 | Brother HL 2140 Laser Printer
If you are getting "clean corona wire" on your PC and the toner light on the machine is solid, you need to change your toner cartridge.
This is a bug in the brother software.
Thanks,
Pat
May 11, 2010 | Brother HL 2140 Laser Printer
Brother not printing
Hi John, the machine keeps asking you to clean the corona wire because on start up or especialy when the machine readies it's self to start printing, it passes a voltage through the corona wire which helps the drum erase the charge on the organic photo compound the drum is covered in.
If the machine sees any problem with the transfer of this voltage it thinks there is a problem.
The corona wire can be cleaned by sliding the blue tab on the top of the drum from right to left a few times.
You should check to see if this wire is broken ..it a very thin wire about the thickness of a human hair, if the wire is not broken then try cleaning the thin metal grid below the corona wire with a cotton bud , being carefull not to break the wire.
If this doesnt work then it sounds like the high voltage connection on the drum is faulty, and you will need to purchase a new drum ( or take it back to the supplier and say it is faulty and you want it replaced).
You ould also clean the surface of the drum itself carefully with a soft DRY clean cloth.
The only other cause is the high voltage supply pcb is faulty. Which if the machine is out of warranty is prohibitavely expensive to repair.
Hope this helps
Mar 03, 2010 | Brother HL 2140 Laser Printer
Get a clean the corona wire. Have removed the
Try using canned air to blow out that corona area, and then a Q-tip moist with alcohol to gently wipe the corona wire, if all that fails you will need a new drum.
Also press the go button 3 times so you get a printout and check that you are getting a clean the drum error or something else.
Dec 18, 2009 | Brother HL 2140 Laser Printer
Get error light when trying to print labels - HL 2140
The driver should pop up a error message. Possibly is due to clean corona wire. Slide the blue lever several times across (at the drum unit).
Dec 10, 2009 | Brother HL 2140 Laser Printer
Printer won't print error message corona wire needs cleaning
When you experience a persistent problem like this right at the beginning - listen to your own good advice. Take it back to the store and exchange it for a new one.
Jul 30, 2009 | Brother HL 2140 Laser Printer
Brother HL-2140 Corona Clean Error Won't Go Away!!!
The error message is misleading. The printer wants a new toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000026/faq002526_000.html?reg=us&c=us&lang=en&prod=hl2140_all
Jun 30, 2009 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
108 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
