Question about Liebherr Refrigerators
I need a new door handal for a liebherr fridge ksves 4360
5 Suggested Answers
  • 4793 Answers
SOURCE: Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Posted on Jul 23, 2010
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
SOURCE: Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Posted on Nov 03, 2010
My Liebherr CNes 3366 fridge freezer has started to build up ice in the bottom of the freezer. How do I check the fan in the fridge is working, (I never see it going)as it may be the cause? thanks r
remove cover and test with a meter or push door switch when door open and should hear fan hum or feel air when door open fan stops unless you push switch
Apr 20, 2017 | Liebherr Refrigerators
I push handal on door and does not make ice motor run got plenty of ice no blockage handal operates shut and open lid seal in door ice throat
pull out the ice bycket,you'll see a metal piece that connects to the auger motor,if you see ice there heat it up with a hair dryer the motor could be frozen or the auger motor is bad,send the model number,also open the door,remove the ice bucket,hold in the door switch and push on the part to let the ice come out,do you hear a humming sound or can you hear the motor run,if not bad auger motor.
Sep 11, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
Apr 22, 2009 | Liebherr K3660-20 Refrigerator
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Refrigerators Logo
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
