Question about Landice L7 LTd Pro Sports Trainer Treadmill
With the L7 plugged in, and after pressing the start button, nothing lights up and the belt does not move.
  • 79 Answers
Looking for a qualified technician to check the connectors on the lower board specifically where the motor wires connected.
this part of the lower board overheats and sometimes there are false contact.
Posted on Sep 12, 2010
Hi having a problem !!
If it has a belt drive, the belt has to be replaced.
Mar 22, 2015 | Technics SL-1210 Turntable
I recently took my turntable out of the box after being in there for years because someone wanted to buy it, but it dose not work.
If the turntable is a belt drive, most likely the belt has probably disintegrated due to ozone contamination over time and must be replaced if this is the case. Once you have the platter off you can see the spindle that drives the platter to see if it is moving.
Nov 22, 2014 | Audio Players & Recorders
My Vision Fitness T9450 is having a power issue. I plug it in, turn on the power button in the back, the console lights up as normal. Then when I press start the power goes out before the belt even st
you have a SHORT circuit maybe in the power supply, transform, capacitor, motor or lower board.
You must call some tech qualified, for to fix it.
see the block diagram.
God bless you
Sep 19, 2012 | Exercise & Fitness
Landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
May 08, 2012 | Landice L7 Executive Trainer Treadmill...
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
Cannon BJC 80
5 times try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
3 times, probably something wrong with the cartridge.
Nov 21, 2007 | Canon BJC 80 InkJet Printer
Landice L7 LTd Pro Sports Trainer Treadmill Logo
217 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
