Question about FlowPro 10254 Floor / Box Fan
We have Mod. # 10255 box fan. One of the blades is bent. Can I get replacement blades?
I have replaced two radiators so far and every time the fan damage the radiator. when installing the new one there is a big space between the raditor and fan. What can be the problem
You may be missing some spacers and/or bolts to secure the fan properly. The fan could also be damaged. For example, the fins may be bent, the shaft is bent/misaligned, the fan blade assembly has seperated from the shaft, or the fan housing is bent or broken causing the blades to hit the radiator.
Feb 03, 2016 | Cars & Trucks
Wobbly blade
If you have a wobbly fan you want to check ALL screws including hanging brachet. If you have a bent blade holder or warped blades they would need to be replaced.
Oct 15, 2015 | Dryers
My fan is swaying and is very wobbly. I'm trying to figure out how to fix it
First, start at the top and make sure the hanging bracket is tight against the electrical box. If your fan has a downrod, make sure the set screw is tight. Next, check the blade holder and make sure they're tight. Then check the blades screws. If one of the blade holders are bent, even a little, they would need to be replaced. And lastly, check the blades to see if they are warped. If so, they would need to be replaced.
May 14, 2015 | Windchaser WCUFLTI Tower Fan
Bent ceiling fan blade brackets
This is what you need to do:
So how do you contact the Hampton Bay Replacement Parts Department?
Simply call 1-877-527-0313 then select option #2. This department will then help you find the replacement part you need for your hamton Bay product.
Dec 23, 2012 | Dryers
My 97 GMC Jimmy Fan problems.
It sounds like a fan blade is bent and is making contact somewhere , these are usually aluminium and easily pushed back into shape , but if the fan has worn out its bearings it will need to be replaced unless there is some sort of material that has wrapped itself around the fan causing it to jam up .
Nov 10, 2017 | 1997 GMC Jimmy
I need a fan moter 4 a utilitech model DQ50Dc high valosity fan
I have one.. mine got knocked over and it shredde the little black 'box' inside there. bent the blades up a bit, but the motor is good. email audioguru76@yahoo.com
Sep 04, 2010 | Dryers
Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All...
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Sep 02, 2010 | Heating & Cooling
Noise from fridge when doors are closed.
There is a good chance this is the culprit.
Servicing the Evaporator Fan
In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Good Luck! Buddy777
May 09, 2009 | LG LRFC25750 Refrigerator French Door
I Have a hampton bay ceiling fan mod. 523 342,
if you have connected power directly to the fan motor and it doesn't turn...replace the fan.  However, also check the switches on the fan as you may have bumped them.
Mar 24, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
Nov 06, 2008 | Kenmore Refrigerators
FlowPro 10254 Floor / Box Fan Logo
73 people viewed this question
Top FlowPro Dryers Experts
Are you a FlowPro Dryer Expert? Answer questions, earn points and help others
