I have a Hoover Nextra 'Awash 1200' washer dryer and it is not spinning at the end of the wash and leaves water in the drum. Any idea what the problem is. Is it a simple problem to rectify or should I just scrap the machine???
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
fanny
  • 146 Answers
SOURCE: hoover nextra 1200
The machine only allows a limited time for all the water to drain out before it starts spinning. If the is a blockage or obstruction in the drain hose or drain pump, the machine will not allow all the water to be pumped out and it will not spin. Check for any restriction especially under the sink/tub where the drain hose attatches to the drain spigot.
Posted on Nov 03, 2007
SOURCE: programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Posted on Jun 01, 2009
  • 574 Answers
SOURCE: hoover nextra washing machine , not draining
take pump off and take apart to clean
Posted on Aug 28, 2009
FitzOriginal
  • 842 Answers
SOURCE: hoover nextra hnf2137 wont drain
Take a look at my article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning Hope this helps
Posted on Feb 02, 2010
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
User manual for hoover nextra tumble dryer
I have a Hoover Nextra washer/dryer machine. It has been working fine but 2 days ago it stopped taking water into the drum. When I put the machine on, I can hear water running into it and the water does go into the powder compartment and clears that. However, only a tiny bit of water is getting into the drum of the machine.
In case it is relevant, there is only one hose at the back, not 2 hoses like some machines have. I don't think it can be water pressure as it has always worked before.
I hope someone can maybe give an idea as to how to fix it as I have toddlers and need it fixed asap. Is there anyway we could fix it rather than have to call out a service engineer. If there is something we can try can you answer in simple language as we don't know much about washing machines.
Thanks very much
Dec 21, 2010 | Dryers
Drum loose so very noisy on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Hoover Nextra HNWL 3136 Front Load Washer...
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Washer instructions need manual
You have a clogged pump.Find access to inside the machine,locate the pump and clean it out.
May 24, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
