Question about Brother Office Equipment & Supplies
Printer mfc9840cdw printing a red & black line down the right side of the page? why?
SOURCE: Black lines on the right side
I have had this same issue, and the people at HP keep telling me it's an application problem. I've never had the issue before I installed the HP LJ 1020. Down the side of any page with any graphics, you get what look like line markers. I have tried reinstalling the drivers multiple times, and reinstalling MS Office 2003, and still the same issue. This issue does not exist with an HP OJ 6110, which I had before. I even had the LJ 1020 replaced, to see if it was just that printer that was defective, but the new printer still had the same issue. My solution is to buy something other than HP LaserJet 1020. And the tech staff at HP were completely UNHELPFUL. They just kept insisting it was not the printer, and it so obviously WAS.
Posted on Aug 08, 2007
  • 30 Answers
SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Posted on Aug 23, 2007
The vertical black line at the right-hand side of the page when the printed document includes an image is a problem with all currently available HP Laserjet 1018, 1020 and 1022 drivers. While waiting for HP to fix the problem (they haven't even acknowledged it yet in their webpage) you can bypass it thus: a) Click on the 'Properties' button. b) Click on 'Finishing' and select 'FastRes1200' (this makes the line narrower). c) Click on 'Basics' and select 'Rotated', i.e. printing the page from bottom to top (this elliminates the line completely, in combination with 'b' above). This is a home-made solution I found after numerous trial-and-error attempts and having downloaded several drivers from the web. As a token respect to all of us who have paid money to buy these printers, I hope HP will soon recognize and solve the problem.
Posted on Sep 25, 2007
SOURCE: black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Posted on Oct 15, 2007
  • 2072 Answers
SOURCE: vertical black line down right side
Did you carefully inspect all through the paper path for some fuzz, or a small piece of paper smearing the print?
The other issue would be the fuser. Do you see any reprinting of images or letters in that area?
What you can do is set the machine to print 2 or more pages and open a cover or turn off the power to jam the prints in the machine. See if the line is on the drum or not. If not then you have a fuser roller issue which would require replacing the fuser.
Posted on Mar 06, 2008
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
OkiC5200 has an inch wide faded print line down the left side
It might be a dirty led assembly. The leds hang down from the top when it is opened.
May 03, 2009 | OKI C5200n Laser Printer
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
