Question about Cameras
When i set to power on, the lens is stuck then a noise can be heard. sounds like a gear that is stuck up. then the monitor becomes blurred not like before.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 25, 2010
Testimonial: "i am contented with your assistance. thank you."
Kia sorento 2012 produce sound look like power steering problem and it gets louder when ever I acceleration gear, so I took belt out and start the engin with no belt I found that sound was in engin!!
If its a knocking sound:
A KNOCKING SOUND IN THE ENGINE IS MOST LIKELY CAUSED BY ONE OF THE FOLLOWING
1. PISTON SLAP: Makes a sharp metallic noise. Idle engine and short out each cylinder plug. The noise will disappear when plug with bad piston is shorted. Noise will also disappear at acceleration. This can be caused by worn or out of round cylinder, or broken piston ring. Correct problem by re-boring cylinder and/or replacing piston.
2. VALVE NOISE: Makes clicking or rattle noise. Caused by excessive wear on valve stem or lifter, out of adjustment, or stuck valve. Correct by adjusting valve clearance, replace worn valve or lifter, regrind cam, replace valve guide and /or valve. A stuck valve can sometimes be loosened by passing oil through the carburetor while engine is running.
3. ROD BEARING KNOCK: Makes sharp metallic noise similar to a piston slap. Detection is opposite of piston slap. Rod knock is not heard at idle. Knock becomes louder as engine speed is increased. Caused by excessive rod bearing clearance. Correct by adjusting rod bearing clearance to .0015 inches by removing shims. May require re-pouring rod bearing.
4. REAR MAIN BEARING KNOCK: Makes dull knocking or thud noise. Detected at speeds between 20 and 50 MPH. Knock will normally decrease or disappear while pulling or decelerating. Noise will be detected the loudest at normal driving speed, when not pulling or decelerating. Correct by adjusting bearing clearance to .001 to .0015 inches. If knock is excessive, crank should be checked for out of roundness. May need to re-pour all main bearings to correct.
5. TIMING GEAR KNOCK: usually the most difficult to diagnose. If gear is loose or badly worn it will knock in all ranges. Run engine slightly above idle speed. Slowly open and close throttle. Knock will continue to be present, but just as engine slows down knock will become a slight rattle. Remove timing pin and reinsert into timing hole on timing gear cover. Press timing pin tightly against timing gear and accelerate slightly above idle. Knock will significantly be reduced or disappear. Correct by replacing both timing gear and crank gear as a matched set. The two gears should have a backlash clearance of .003 to .004. If more than .009 inch backlash, an oversize (.005) timing gear should be installed.
6. WRIST PIN SLAP: This can not be detected by shorting out the cylinder plugs. Rapidly accelerate and decelerate the engine speed. The engine will pass through a certain speed range when the wrist pin will rattle at about the same pitch as a valve tappet noise. This can be corrected by installing a new wrist pin bushing in the rod or new wrist pin f badly worn. Wrist pin should fit the piston and connecting rod with a tight metal to metal fit. The pin can be pushed into the piston and rod with a slight pressure of the hand. Pin to rod clearance is .0003 to .0005 inches.
Dec 15, 2013 | Kia Sorento Cars & Trucks
IXUS 75 LES IS STUCK OUT , LCD READS [ lens error. restart camera]
that is the usual problems.
1. check battery
2. format the memory card, but backup first the data unto it.
3. format using the camera itself. this keep the system of the camera restore again.
4. observe if you on the unit you will heard a sound that noise something of drastically pulling the plastic gear. if you had hear this means that your unit has been on without a notice and sometghing had blocked it. it affects the tiny motor. this need an alignment at first.
5. Try to open with yourself but if not, seek someone to do it for you. a small tip philips screw driver can help you. align the cover of the lens you can pull out the center where the lens. open the back cover and slowly get the screw. do not place the lens rub on you desk because' it could damage the lens. then you will see a gear that be rotated by your finger, try to spin slowly the gear and it should be affect the layer of the lens over to move up and down. should be freely to move up and down. try to clean. then return to its place and assemble again your unit.
 email me: luigieadm23@yahoo.com
May 19, 2011 | Canon Cameras
Hi, my Nikon Coolpik S8100 camera lens seems to be stuck and not extending. When I turn the camera on, it makes a clicking sound and the lens does not come out. Please help!
try manually pulling on lens housing while powering on. if there is a grinding noise the gears are probably missing teeth.
Mar 21, 2011 | Cameras
Lens stuck open position
you can try a couple of things genltly twist the lens one way until you hear a sound,turn off and try powering up again,also particles of dust or dirts can become cloged of lodged in the gears that move the lens, this may cause the lens to stuck,try blowing the area between the lens barrel and the camera body to remove some dust and dirts. hope this helps
Jan 03, 2010 | Canon PowerShot A560 Digital Camera
On the lens makes a clicking noise shutter goes in and out turns.
Did you drop it? if you did you have damaged the gear drive motor for it. Are the batteris good?
Jul 06, 2009 | Olympus FE-210 Digital Camera
Buzzing sound
the problem is with lens.this sometimes happens if cam becomes victim with water.
there is some buzzing noise when the shutter of lens gets opened or closed.
please clean the lens with the solution once.then you can make out of blurs.
Apr 04, 2008 | Samsung Digimax S630 Digital Camera
Lens does not fully extract
Your lens track is the problem, if you could open your camera check the lens gear if its teeth are complete. If so check if something stucks on it. Its much better to bring your camera to an authorized service center to re timing your lens track... ^_^
Jan 14, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens is stuck open/extended
Im having the same problems with mine, I can view my pictures, but the lenses is stuck out, beeps a few times and then I get the E18 error. I tried everything at http://www.e18error.com/repair.html but still no luck, ready to take it apart and see what is stuck
Aug 20, 2007 | Canon PowerShot S2 IS Digital Camera
Out of Focus
Have you tried to clean the lens?
Jun 20, 2007 | Pentax Optio X Digital Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
