Question about Craftsman 25cc Gas Line Trimmer
NEED PARTS FOR ROPE AND SPG. - Craftsman 25cc Gas Line Trimmer
    President:
  • Craftsman Master
  • 1,545 Answers
Small engine repair shops carry alot of these kind of parts...so does Home Depot. Or you can go to:
www.searspartsdirect.com and enter your Craftsman model number (if that is what you have) and see a manual with all your parts listed in diagram form with pricing too if you choose.
Posted on Aug 25, 2010
How do i fix the pull cord when it breaks
You need to take the cover off of the pulley and the spring loaded spinner, housing the rope..the pulley is sitting on the top crank shank of the motor..the spinner sits on it..the rope is attached to the spinner via a knot in a slot or hole..remove the old broken rope and measure the two parts..using an equal amount of new rope attach the new rope using the old one as an example and wrap it clockwise until there is enough rope left to be fed back through the cover..and attach the T handle Note..the T handle should have a small door on one end to feed and tie the rope on..you can see this when your remove the old rope from the T handle..should be ready to go..just watch the steps when removing the broken one and do in reverse..Good luck
Sep 30, 2014 | Weedeater 25cc 2 Cycle Gas Blower -...
How does the recoil spring,waher,2 hairpins pins,dog footand rope pulley get reassembeled?
the rope rotor will go on first, then the washer goes on, put the dogs in then put the spring on. insert the rope into the rotor, wind it up, feed the rope through the starter cover, carefully allow the rotor to wind in the rope a ways then put the handle on.
Dec 20, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Scubapro mk 17 slow to move spg needle
the spg hose has a oriface in it so that if the hose burst you do not lose all your air underwater at once. have your scuba shop test it for proper operation.
Aug 08, 2012 | Scubapro MK17/S555 Regulator
Spg rising slowly
You should open the tank valve slowly if after opening i takes more than 3 seconds to get up to pressure something is not working properly. FOR SAFETY GAUGES ARE SUPPOSE TO BE FACING AWAY FROM U WHEN PRESSURIZING. IF GAUGE IS DEFECTIVE AIR PRESSURE CAN BLOW GAUGE LENS OUT FRONT OF GAUGE.
Apr 18, 2012 | Cressi-Sub CressiSub Mini SPG SCUBA...
Looking for replacement parts for SPG90B Campcheif Big Gas 3
I looked around online and could not find anything for my gas grill. My burners all disentergrated. I found Walmart is a good source for cheap generic grill parts but only at certain times of the year. I recently replaced 3 burners on my gas grill. The new burners were build like a trombone so one size fits any grill. The metal looks a lot better than the original equipment. At $10 a burner I am back in action!
Sep 29, 2010 | Camp Chef Big Gass III - SPG-90B Grill
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
May 27, 2010 | Mtd Products Yard Machines 158CC Tiller
Unable to update service
download the update service from sony ericsson website http://www.sonyericsson.com/spg.jsp?cc=gb&lc=en&ver=4000&template=ps1_1_3_1_1&zone=ps&lm=ps1_1&pid=10183&fid=21839&esi=true also you may need the new USB drivers for your sync station http://www.sonyericsson.com/spg.jsp?cc=gb&lc=en&ver=4000&template=ps1_1_3_1_1&zone=ps&lm=ps1_1&pid=10183&fid=11349&esi=true
Aug 15, 2007 | Sony Ericsson P910i Smartphone
Craftsman 25cc Gas Line Trimmer Logo
47 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
