Question about Siemens Gigaset 2420 Cordless Phone
Gigaset 2420 Siemens
I recently had my father send me a Gigaset 2420 system as I am a poor college grad. Upon hooking up the base unit the orange buttons occasionally flash as the unit restarts itself. My parents had cats that chewed on the power supply, I am wondering if this my be the reason, or if the problem might be internal. Any input is greatly appreciated... Thanks!
    Novelist:
  • 106 Answers
You may have the wrong or defective power supply. Or, that problem is common from getting a power surge and the unit will probably have to be sent in for repair, sorry.
Posted on May 10, 2008
SOURCE:
Siemens gigaset 2420. how do i reset pin on desktop base corded station?
  1. I forgot the PIN number on my Gigaset 2XXX system base station. What can I do?
    Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
  • Press MENU.
  • Scroll to SYSTEM SETTINGS but do not press SELECT.
  • On the keypad, enter *65# (Star, 6, 5, Pound).
  • It will display "SYSTEM PIN RESET" and return to the idle screen.
  • Note: The base station system PIN will be reset to 0000
  1. I forgot the PIN number on my Gigaset 2XXX cordless handset. What can I do?
    Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
  • Press MENU.
  • Scroll to MOBILE SETTINGS and press SELECT.
  • Scroll to LOCAL SETTINGS and press SELECT.
  • Scroll to CHANGE PIN and press SELECT.
  • Note: The handset PIN will be reset to 0000
Jan 05, 2010 | Siemens Gigaset 2420 Cordless Phone
Need a master PIN
To reset the Gigaset 2420 Pin
At "System Settings" in the Menu press *65# then press the Select button.
"System PIN Reset" will be displayed (if the PIN was not already the default).
The default PIN is 0000.
Goodluck..
May 14, 2008 | Siemens Gigaset 2420 Phone
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
System pin reset
try using all zeros usually 5 zeros
Dec 01, 2008 | Siemens Gigaset 2420 Phone
System pin # reset
There is a way to override and reset... I think you need to press *67# when in the system pin area via menu. Confirm this first though. There is a way to do this though- then you reset it to 0000- google it and you will find the answer-
Problem Siemens Gigaset 4000 and 4200
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Siemens 825 Gigaset
I have the same problem with mine - a Siemens 2420 base. The calls come in, all the lights flash, then the thing clicks and resets. At this point, it can only be used for outgoing calls. i think i'm going to retire it. Too bad, cause the speakerphone was one of the best ever.
Nov 28, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens 2420 Phone System
I had the same issue a while back and I believe a new power supply fixed that problem. If you know anyone with a multi-meter and they know how to use one they can tell you if your power supply is bad or not putting out enough voltage. I believe this system requires 12 volts and 400 milliamps it will say on your current power supply.
Aug 31, 2007 | Siemens Gigaset 2420 Phone
Siemens Phone
I just replied to a similar post. This is a common problem, not only with the Siemens but most all manufacturers that used this design of display on many different devices. And in this case, the display connections are pressed on with a special machine and can't be replaced by a do it yourselfer. Sorry I can only recommend sending it in for repair.
Aug 21, 2007 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 Desk Staion LCD Display
That is a common problem with those types of displays, they are sensitive to heat, cold and any movement. They were used by Siemens, and almost all the other manufacturers during this time period. Unfortunately on this particular model, they are not soldered in, they are pressed on by a machine. So if you don't have a Zebra cable press machine ($1000's), and a brand new display, you can only resort to sending it in for repair. Sorry.
Apr 28, 2007 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
479 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
