Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
My son's four wheeler power wheels is making a clicking noise and tire is slipping when he goes to drive it. It sounds as if the gears are stripping or not lining up. Any idea how to fix it?
3 Suggested Answers
SOURCE: power wheels 4 wheeler problem
pontiac powerwheel stuck in reverse
Posted on Apr 27, 2010
SOURCE: Power Wheels 4wheeler sounds like a jackhammer but no movement
My sons is doing the same thing, I went into it and found a gear with the teeth stripped off, I have yet to find a place to purchase the gears, but if I do I will post the source, if anyone else does please let me know at jasonegore@AOL.com
Posted on Sep 15, 2011
Polaris 325 magnum
It sounds like it could possibly be the ring gear in the rear differential. (Where the drive shaft enters the diff.) If the ring gear gets stripped the drive shaft will turn but it's not transferring that power to the rear axle. Lift the rear end off the ground and spin the rear wheel by hand. Listen for a clicking sound at the rear differential. If it is clicking then I would bet the ring gear is stripped.
Nov 17, 2017 | Polaris ATV
A womp womp womp noise in the rear, tires are good, brakes look good, wheels are not warped, just had them balanced?
Go to a place that has a good smooth parking lot and a wooden private fence. Open all your windows and drive the car slowly as close as possible along the fence in order to pin point where the sound is coming from. The sound will echo back from the fence and will make it easier to pin point the area where the womp womp sound is coming from. Next thing you can do is lift the car up and place it on four jack stands in case you have a front wheel drive. If you have a front wheel drive and your car is on four jack stands, place you gear in nuetral and spin each rear tire separately to see which one is making the noise. Keep in mind that it might be a wheel bearing or if it a rear wheel drive and on four jack stands have someone drive it slowly while you listen for the noise. Some rear wheel drive differentials can make this noise if it is low on differial oil. Be very careful that the jack stands are on solid and making good contact with the car frame and flat on the pavement. Don't place yourself where the car can fall and hit you or run in to you. Good luck.
Dec 03, 2012 | 2002 Porsche Boxster
What is the horible noise when four wheel drive is engaged?
problem cv joints and or "U" joints and or worn slip joints in drive lines
no make model year listed so impossible to know exactly
Mar 27, 2017 | 2002 Nissan Xterra
Hello, with all 4 wheels off the ground,engine running and in gear only 3 wheels are turning. The right front does not. is this normal?
Unless you have a positraction rear differential, I'm surprised that even three are turning! Four wheel drive is really two wheel drive because both differentials are "open" type. In an open diff, only one wheel has power at any given time. With a positraction, or "limited slip" rear diff, both rear wheels push with fairly even force but the outer wheel is allowed to slip when going around turns. Only true four wheelers have either a limited slip on both ends or "locked" units but it is impossible or really difficult to drive anything like that on the street. If you hold the left front wheel from turning unless the locking unit is broken, the right front should turn.
May 10, 2010 | 1998 Jeep Grand Cherokee
The wheels on my son's train only makes clicking noises
wheels are stuck and the gear drive is jumping over the gears
Feb 09, 2018 | Toys
Jul 08, 2009 | Fisher Price Power Wheels Kawasaki KFX...
Noise when in 4 x 4
Bad news... It sounds like you have a broken/stripped axle. I would start at the wheel and start disassembling from the outside in. It may just be a stripped spline in the spindle.
Feb 09, 2009 | 2006 Chevrolet Silverado 1500HD
Volvo XC70, Grinding Noise
sounds like c/v axles (front drive shafts) they will make a clicking sound normally when turning sharp and accell at the same time at slow speeds / look at the axle boots and look for grease on the inside of the front wheels leaking out the axle boots
Oct 07, 2008 | 2001 Volvo V70
1993 jeep grand cherokee laredo 4 wheel drive
I'm not absolutely sure on the tire size for the jeep itself, but I think they are 225/65/R15's. Not absolutely sure.
As for the noise, from your explanation, it sounds like the transfer case is under a heavy bind. Take it off of the road in some grass or dirt and then move it forward a few feet then simply hit reverse. Don't move much maybe an inch and it may release the bind. Once you get the bind off the transfer case, it should slip out of 4wd, unless there is damage in the case/shifter itself.
When operating four wheel drives, with tires of different sizes it causes extreme stress on the gearing in the transfer case. Larger tires don't turn the axles as much as smaller tires. So, this causes stress in the driveline as the front is actually turning slower then the rear. In turn, this will put so much pressure on the gears that it could cause damage and the shifting mechanism will not work correctly to pull it out of 4wd engagement.
Try those ideas, and see if you can get it out of 4WD. Definitely put four tires on the jeep that are all the same size. This will keep you from having excessive stress on the transfer case and gearing therein.
I hope this helps out buddy.
Sep 21, 2008 | 1993 Jeep Grand Cherokee
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
464 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
