Question about Dryers
Need to fix a belt - Dryers
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Some machines have a top that hinges and tilts to the back.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards so you do not have to be removed the top completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Aug 25, 2010
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
Jan 02, 2018 | Canon Office Equipment & Supplies
Stuck drivers seat belt. is there a simple fix?
The simplest fix is to fit a new belt. Don't mess around with seat belts, your life is worth much, much more. Some manufacturers are starting to suggest a seat belt replacement after 3- 4 years.
Mar 11, 2015 | 2008 Toyota Tundra
TIMER BELT BREAKING
I am assuming you mean timing belt as these cars did not come stock with timer belts. You need to get a timing belt and fix it. Just hope that when the belt broke you did not bend any valves as that will be costly to fix.
Jun 17, 2014 | 2001 Mitsubishi Galant
How to fix a belt that is making a loud noise on a 1994 Ford Taurus
If it is a loud squeaking sound, the belt is stretched out too far for the tensioning pulley to take up the slack. Check if the belt has grease or oil on it. If it does find the cause, fix the cause and then change the belt...there is no tension adjustment to be made,
Jan 14, 2013 | 1994 Ford Taurus
I have an old White, model STD270 with a disintegrated belt
A belt replacement should be easy, first you need to measure how long a belt is needed by taking a piece of twine and placing it where the belt will go and using it to measure how long the belt need to be. Belts come in different sizes such as 14 1/2, 13 3/8 etc.
May 22, 2010 | Sewing Machines
The plastic tank on the driver's side was leaking coolant. Before we could get it fixed the serpentine belt broke. I would like to attempt to repair both myself but need some advice.
YOU HAVE TO BUY ANOTHER OVERFLOW JUG WHENEVER YOUR OVER FLOW JUG LEAKS.IT HAS A COUPLE SCREWS HOLDING IT IN PLACE.EASY FIX.FOR YOUR BELT.YOU NEED A DRIVE BELT TOOL TO TURN THE TENSIONER BOLT FOR BELT REMOVAL.
Nov 12, 2009 | 2000 Chevrolet Silverado
Hi i need to fix the belt that rotates the dryer
MOST SERVICE COMPANIES WILL HAVE A BELT, OR RING SIMPSON ON 131350
BEFORE YOU FIT THE BELT MAKE SURE THE CENTRE PULLY IT GOES ON SPINS FREELY- IF ITS TIGHT IT WILL RUIN THE NEW BELT.
Jul 06, 2009 | Dryers
How do I tighten the AC belt
Should be a self tightening system. If belt is loose then more than likely a pulley is going bad and needs replaced.
Jun 15, 2009 | 1997 Plymouth Voyager
2002 Nissan Sentra
its your engine belts need to change them. have a nice day
Dec 18, 2008 | 2002 Nissan Sentra
Timing Belt
I want to know how to set point
Oct 08, 2008 | 1996 Dodge Stratus
Dryers Logo
14 people viewed this question
Top Dryers Experts
