Question about Hamilton Beach 57101 BlendMaster Work Top Blender
I have an Oster blender, model #6710, and the gear on the bottom of the pitcher where it sets in to the base has become unsaudered. I have only had the blender for 4 years. Is this unusual or normal after 4 years and is this something that Oster will replace? Any help on this would be greatly appreciated. Is there a number I can call for advice or guidance as to who I should talk to first? Thanks pfamolaro@cox.net
  • 8,596 Answers
The part that you need is available from Oster, and their phone number is 1-800-334-0759. Their standard warranty is 1-year, so you would probably have to pay for the part. 4 years is decent for a blender - if you replace the part, an Oster will most likely last many years longer. While it is not uncompletely unheard of for a blender blade assembly to come unhinged, it is statistically infrequent - the replacement part will most likely last as long or much longer.
Posted on Jun 04, 2009
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
I need a replacement Pitcher
Just go to your search engine (I use Google Canary) and type in "replacement pitcher and manufacturer, model name and/or model number". If you look on the base of the unit it should have the model name and number for you, usually on the bottom.
Mar 26, 2015 | Blenders
Oster makes a high-itch whining sound
Sounds like the bearing for the blade on the bottom of the pitcher may be in need of replacement.
Aug 13, 2017 | Oster 4094 Designer Classic Beehive Work...
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
Jun 24, 2010 | KitchenAid KSB5 Professional Stainless...
Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Mar 19, 2009 | Oster Blenders
Oster 6700 Blender
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives.
This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
Hope this might help Good Luck Loring
Oct 25, 2008 | Oster 6700 Work Top Blender
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Open Questions:
See all Hamilton Beach 57101 BlendMaster Work Top Blender Questions
Hamilton Beach 57101 BlendMaster Work Top Blender Logo
250 people viewed this question
Top Hamilton Beach Blenders Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
eyecam
Are you a Hamilton Beach Blender Expert? Answer questions, earn points and help others
