Just installed new Pstitch Pro vs 9. Trying to create my own pattern and when I click a color from the color palet and try and put on the grid, it always comes out in black no matter what I do. Prints in black also. Patterns I choose from the library are in color. Thanks
  • pcheatham07 Aug 26, 2010
    Thanks for the help. I will try it and see how it works.
The reason it prints in black is because you will need to download the pattern viewer, click on the link below to get started:
http://www.pcstitch.com/PatternViewer/PatView.aspx
Posted on Aug 26, 2010
  • 2,973 Answers
Friend,
Where you seem to be going wrong is in selection of colors. It is not only selecting it but also ensuring that the selected color has been dragged into the selection box meant for selected colors. From here only can you actually select the colors that will display and print in your designs. All the best with your designs.
Posted on Aug 25, 2010
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
How do i clean a printhead?
When print heads get clogged, image quality suffers. But cleaning print heads is a quick and simple process. Here's a step-by-step tutorial on cleaning print heads. This is how i did it with my Canon Pixma MP530 but most printers will work in much the same way.
1. Click the Start button at the lower left corner of your screen.
2. Click on Control Panel. Next, choose Printers and Other Hardware, and then View Installed Printers or Fax Printers.
3. When the Printer page opens, right click on your printer's name, and choose Printing Preferences.
4. For the Pixma MP530, the Printing Preferences has five tabs across the top; choose Maintenance. Again, most printers should have a very similar set of options
5. The first button is for cleaning the print heads. You'll have to choose which print heads you want to clean (the Pixma inkjet has five cartridges). The best bet is to choose All Colors.
6. Make sure the printer is turned on and that there's some paper loaded, then click on Execute
7. The printer will print out a pattern with a grid along the top and six bars of different colors. Two images will display on your monitor that you can compare to the printed image. In one, the grid and colors are sharp and clear; in the other, some of the grid boxes are missing and the colors are striped.
8. If the printout matches the sharp, clear image, simply click Exit and you're done
9. If the printout has missing grid boxes or stripes, then click Cleaning. Once that's done, you'll repeat the whole process so you can ensure the cleaning was completely successful. It may take two cleanings if your print heads are really clogged
10. If, after two cleanings, you're still getting a poor result, there's a Deep Cleaning option on the Maintenance tab that should do the job.
I hope this information will be helpful. Thank you for using FixYa!
Your Feedback is greatly appreciated.
Feb 25, 2011 | HP Office Equipment & Supplies
How do you clean HP print heads
  1. Cleaning a printer's printheads is an easy process. Here's how it works (in Windows). Click the Start button (or in Vista the Windows icon) at the lower left corner of your screen.
  4. For the Pixma MP530, the Printing Preferences has five tabs across the top; choose Maintenance. Again, most printers should have a very similar set of options.
  5. The first button is for cleaning the printheads. You'll have to choose which printheads you want to clean (the Pixma inkjet has five cartridges). The best bet is to choose All Colors.
  6. Make sure the printer is turned on and that there's some paper loaded, then click on Execute.
  8. If the printout matches the sharp, clear image, simply click Exit and you're done.
  9. If the printout has missing grid boxes or stripes, then click Cleaning. Once that's done, you'll repeat the whole process so you can ensure the cleaning was completely successful. It may take two cleanings if your printheads are really clogged.
Oct 03, 2010 | Computers & Internet
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
I have a Sharp Aquos TV that only displays a colorful grid.
your t-con board is failing call a tech to install a new one
Sep 19, 2009 | Sharp LC-60C46U LCD TV
3 screen colors have separated and screen is bowed in the middle.
I take it this is a projection TV. so they use three lensed CRTs red green and blue. you should have a setup screen that projects a grid pattern. red green and blue. there is SOMEWHERE a adjustment that overlaps the three projected grid patterns. Making a WHITE single grid pattern. red green and blue make white light. Pin cushioning is the bowing. you may find a POT to adjust on the back of the set. I have no idea what set you have.
Lastly.. Pin cushioning can also be caused by faulty flyback transformers.
Hope I could help.. new here LOL
Happy Fixing =)
Jul 12, 2009 | Televison & Video
I downloaded paint shop pro 9 and my palletes gradients etc..
On paintshop pro 9 and I think on 10 too, click on "View" on the top menu bar and select "ToolBars". When the ToolBar window opens, select "Color Pallet". You should now have your color pallet back. Close "ToolBar" and carry on.
May 28, 2009 | Corel Paint Shop Pro® X Full Version for...
Magenta vertical stripe sets plus grid dots problem
Try using a diffrent computer on this and see if its not the video card doing it or if not its the controller board inside that connect to the video card that would need to be replaced at this time, if there are no dead or stuck pixels it might be worth replacing rather then buying a new one.
May 14, 2009 | Acer P191WBD LCD Monitor
Colors out of alignment; curved lines
this sounds like a convergence issue.. one thing you are going to want is a good test dvd.. avia - guide to home theater or video essentials are two very good ones. anything that will supply you with test patterns and let you pause on them will work.
you will need to get into the service menu, using your remote press DISPLAY, 5, VOL+, POWER in quick sequence. once the screen comes up you should have green letters and numbers at the top of the screen. at this point, keys 1 and 4 change the item, keys 2 and 5 change the category, keys 3 and 6 change the value, mute enters write mode, enter executes it.
you will want a test pattern displayed that has a center point, enter the pje section of the menu and go to tphp, if you don't see a crosshair, press 6. you are going to want the convergence grid and the test pattern displayed simultaneously, so press 9 until both are on screen. it will be a crosshatch pattern overlaying your test image. use the joystick button (left or right) to roughly line the crosshatch up with your test image.
now go to tpvp and use the joystick (up and down) to finish lining things up. once you are happy with the changes, hit mute then enter to save it to memory.
this next part is from a tweaks file in the public domain that i have for this model and use any time i am working on one of these.
How to Enter the Convergence Mode
Once you're in the service menu, you need to access the convergence mode. Press the 2 or 5 key until you see PJE in white blocky letters (you should be able to get there quickly by pressing 5 once or twice). Now press 9 on the remote. You will see a bracket appear in the middle of the screen. Press 6 and cycle through the different types of patterns until you get a white grid on a black background.
Controls
Once in the convergence mode (activated by pressing 9 in the PJE section), the buttons on the remote work differently. Keys 1 and 4 move the cursor around on the grid (convergence points) in a spiraling fashion. The joystick on the remote will adjust the position of the current color at that grid point. Key 3 cycles between red, green, and blue adjustments.
You may also depress the joystick, which will allow you to move the bracket freely around the grid. Press it again and you are back to being able to adjust the position of the current color at that grid point. Handy if you are just touching up an area and don't want to spiral through all the points.
How to Converge the CRTs
It's much easier to converge the set if you can see what you're converging. Green should be the color to converge to. The geometry (straightness of the grid) of the green CRT should be good enough - If you notice that some lines are definitely out of whack, you should straighten them.
We need to disable the red and blue CRTs. Press 2 until you get to the 2150P-2 category. Cycle through the items until you get to RGBS. Change the value to 2 (Green CRT Only).
Move back to the PJE category by pressing 5. You should be back at the grid with a green bracket - If you don't see one, press 3 until you do (the bracket may have been set on red or blue, which have been turned off). Navigate around the grid, correcting any obvious errors. Once you're satisfied, turn the red CRT back on (RGBS value of 6, Red and Green CRTs on), and return to the grid. Press 3 until the crosshair is red. Now, align the red to the green, getting as close as you can. By the way, not all grid points are selectable. Keep in mind that the edges of the screen will tend to be more out of focus, and harder to get "tight". Get it as close as you can. You also may notice that some points affect the position of other, nearby points. You'll get the feel for it after a short period of time. Now, do the same for blue, making sure to turn off red (RGBS value of 3, Blue and Green CRTs on). When you're all done, turn all the CRT's back on (RGBS value of 7, All CRTs on), and look to see the results. Touch up where it is needed (if needed at all).
I found the 100 IRE Crosshatch image really showed areas that still needed convergence. I would cycle within the PJE category (pressing 6) between the convergence grid (to fix errors) and the 100 IRE Crosshatch image (to view areas with convergence problems).
Save your convergence to memory by pressing MUTE followed by ENTER.
Remember, you need to do this for each mode you use - This doesn't mean for each input. It applies to 4:3 mode, 16:9 mode, and 1080i 16:9 mode (even though 1080i is a 16:9 mode, it requires its own convergence due to the higher scan-rate). Each mode is separate, and is saved separate, however, each one does tend to affect the other slightly.
Try not to use the Flash Focus. I know it's very easy to use, and they put it right there on the front of the set, so it basically begs to get pressed. But realize that pressing Flash Focus will rely on the sensors to converge your set - It will pretty much re-do all your hard work. It may get close, but it will never be as good as a service mode convergence.
Now that your convergence is done, you should re-register your new convergence to Flash Focus (FF). Ryan says below don't use Flash Focus, and I agree. However, if you do or someone else does, it shouldn't require nearly as much touching up if the new convergence is re-registered to Flash Focus. This is simple to do. While in the PJE category, press the Flash Focus button to initiate a re-registration process to the system. If the operation fails (I've never had this happen), press 0, followed by ENTER to restore the convergence settings you last saved. You'll need to investigate why it did not work. In the PJE category, change to item ERR and it should read a value other than 000 if your attempt at re-registering FF didn't work. If our attempt at re-registering did work, it should read a value of 000. Typically, reasons why re-registering FF won't work are due to overscan being reduced too much but there are other reasons too. Regardless, while you are investigating just don't press FF and you'll be fine.
I have read numerous forums regarding re-registering flash focus. Most say only re-register flash focus in Full. This is what I did. I only watch TV in Full mode anyway, so it worked well. I have read many people having troubles with other modes if they re-register flash focus in Wide Zoom mode so I can only say, read forums and ask questions if you do use your set in other modes before you re-register your flash focus in another mode besides Full.
hope this helps you,
trin
Nov 15, 2007 | Sony KP-51WS500 51" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
