Question about Garden
SS30 model does not want to take the gas and rev -up will rev with the choke on
  • 183 Answers
Your Ryobi SS30 is starving for fuel. Depending on which carb they installed on your trimmer will determine the needed repair. If your carb has adjustable jets on it, remove the plastic locks from the screws, and turn the low side (closest to cylinder) counter-clockwise 1/4 turn and test run. Turn out another 1/4 turn if necessary. If this doesn't solve the issue, or if your carb has non adjustable jets, then the carb must be rebuilt or replaced.
Posted on Aug 25, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
My friend owns a 1995 Mercury Mystique.She had a new starter put in and after that the car will start but you cannot rev up the engine to drive it. If you rev it up very slowly the engine will rev,but if...
replace the fuel filter, first, if there is no check engine light, if that does not fix the problem ck the fuel pressure for possible fuel pump failure
Sep 01, 2013 | 1999 Mercury Mystique
14" CRT 3.5 hp tiller,
Make sure your Air cleaner is not obstructed. Clean it!
Check your spark plug for the proper gap. Adjust your
LOW speed throttle screw. It may not be getting enough fuel flow. Check your fuel filter screen (Inside your gas tank). Good Luck
Sep 19, 2017 | Craftsman Garden
When I rev the throttle it kills the bike. But
You carburator needs cleaning, or needs to be adjusted. Do you have fresh gas in the tank? Did you mess with the jets, or any adjustments on the carb? You're just not getting enough gas when you open the throtle, and having the Choke on will give you more gas.
Oct 19, 2009 | 2005 Honda CRF 250 X
Ryobi ss30 weedeater,my weedeater seems to be flooded.need help
Give lots of details when describing the problem. When it started, was the choke on? If the choke is on, try starting it with the choke off, or starting it with the choke on and immediately taking the choke off when it starts, but keeping your fingers on the choke so you can turn it on again if the motor begins to die. As others have described, you have a problem with the mixture screws not being set right or the carb diaphram being damaged. Your owners manual may tell you what settings to start with on the mixture screws, or you may be able to google the model number and get the manual online if you don't have one. At this point you should have taken the carb apart to look for problems and blow out the air and fuel passages. You are making progress. At least you know that it is getting spark, and getting gas. I am not familiar with that model, but many of them have three settings for the choke, fully on, half on, and completely off. If you have that type, after it starts and dies, take out the plug and dry it, then try starting it with the choke half on. You will need to clear out the excess gas while you have the plug out.
Jul 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
1984 aspencade starts w/choke and revs up, runs smooth. Take off
My 'wing won't run unless it has been warmed up some. I would suggest that you r&r your carbs to make sure the jets in the bottom are working correctly. They tend to get plugged up, especially after sitting & the aluminum flaking off inside... Rick
Apr 05, 2009 | 1982 Honda GL 1100 Aspencade Gold Wing
Garden Logo
586 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
