Model XC1044 a black/gray washer with teeth (cog) snapped so that the paper will not enter the fuser. (stops with a 1/2 done page). Can we purchase the cog to replace the broken one?
    President:
  • 2,072 Answers
Contact this business.
https://www.partsdrop.com/store/
Thats not a hard part to replace, nor is it expensive.
Posted on May 05, 2008
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
HP 1012 paper coming out creased. ?something stuck to drum or roller
If it is a clicking sound it's most likely a gear that is bad. Haven't worked on this model, but typically it is one of the gears that works in tandem with the fuser that goes bad. These can be purchased on hp's site. Remove the fuser and inspect all the gears. There usually is a small plastic clip you have to remove to get at the gears. Inspect the teeth on the gears (they should be smooth) If it's not one of the fuser gears it could be one of the gears on the main gear assembly. This is considerably harder to access.
Jul 16, 2012 | HP 1012 Laser Jet Series Q2461A
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
Our HP 4250N Laser Printer is leaving a black line approx 2 inches off left side of paper. Tried cleaning rollers and putting printer into clean mode. Nothing is working. Any advice? Thank you.
This is caused either by the fuser or the tonercartridge.
The most common cause is the tonercartridge.
You can test this by forcing a paperjam to stop the paper just after the toner but before the fuser.
To force a paper jam print you can print a page from the manual feed tray and as the last third of the page enters the printer opening the door causes it to halt.
If the black line is there before the toner is bonded to the paper by the fuser you should replace the tonercartridge..
Jan 04, 2011 | HP LaserJet 4250n Printer
BLACK LINE
Greetings,
usually this would be either a cartridge or a fuser.since you changed a cartridge and it's still there.most likely it is the fuser.
you could double check by doing a half stop test.start a print from tray 1 and when the trailing edge of paper is just entering the machine,open the printer to stop print and take out the cartridge,open it's shutter and look at it's drum and the paper just underneath.if the issue ios not at either of those places,then probably the fuser.
if you take out the fuser ,you may be able to see an issue with a fuser roller.like a tear or other anamoly.
Also More than likely your fuser is peeling. Pretty easy to check...power down printer and pull rear door then unlatch the fuser and look at the fuser rollers...more than likely the bottom roller is peeling on one side...you'll know it when you see it...
Regards,
TechSup1
May 01, 2009 | Lanier 5235 Printer
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Charlotte
Apr 17, 2009 | HP LaserJet 5500DN Printer
Need a developer drive wheel for a mfc-8440, its in the back of the machine on the internal right size, its plastic, black in color, has teeth and both my machines have broken ones, the machine jams the...
THIS SEEMS LIKE THE FUSER SECYION THAT YOU ARE TALKING ABOUT, IF THIS ISTRUE, YOU CAN NOT BUY THE GEAR YOU WILL HAVE TO REPLACE THE FUSER UNIT BROTHER TECH
Jan 05, 2009 | Office Equipment & Supplies
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
jasbo
jasbo
