Question about Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery
My electrolux Icon side by side counter depth fridge is making a knocking noise in the ice maker region. All aspects function perfectly, but the noise is getting increasingly loud.
SO I have/had this problem. The knocking started almost 3 months ago when I got it. IT got to the point where the ice make will not work.
Just had the repairman out. He started out clueless but over the course of an hour he had the factory on the line, and got it resolved, I was watching over his shoulder.
The ice mold is on a cam. It drops down and around to the right to fill with water, and then back up into the center to freeze the water. HE got a kick out of how it worked, it is kind of cute.
When its going to the right to fill, there is a plate in the back right hand side that covers the copper freon line, it protrudes into the path of the ice mold. As ice/frost build up it bends it more to the point it will prevent the mold from swinging into the position to get water. Thats what happened to me.
There is a kit to fix. He did a temp fix:
1) With the Ice tray out.
2)Remove 2 screws on the front lower part of the ice maker and slide cover off.
3)On the right side 2 freon lines come into the ice maker there is a piece of plastic, maybe 2-3 inches square, with a slight offset to it. That's the problem piece. Remove it, and bend it a touch so it pulls it out of the path of the mold.
4) Reassemble.
WHen my kit comes, I'll just re-install it myself.
Posted on Sep 10, 2010
Ice maker makes knocking noice
It would depend on the model of your fridge. Most fridges, you would just need to change the icemaker, but if it is a whirlpool or kitchenaid, you can just replace the module on the front of the icemaker (part number 8201515)
May 19, 2012 | Electrolux Refrigerators
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
I have two problems with my 2003 Electrolux refrigerator (model # FRS23H5ASB6). 1) We just replaced the water filter, but now the ice maker will not make ice. The lever is in the on/down...
There is no power up there - best you get a schematic for the unit so you can figure it out. The site enclosed often has schematics for this type of appliance. All you need is an ac voltmeter and you are ready to start checking. Search Over 2 1 Million Appliance Parts
Sep 05, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Ice keeps building up in bottom of freezer and on vent inside fridge and now fridge won't stay cold.
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 14, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Open Questions:
I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defros I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defrost. The top part of the freezer was heavily encased in ice (evaporate coils I think). After perusing the web for advice I removed the the front vent, the back wall and dropped the coil panel to access the fan. The fan had obviously not been working for some time cos it was covered in ice. I defrosted the whole fridge for 2 days. Turned it back on and the freezer part seems fine although v cold. The fridge seems not to be cooling again. The compressor seems to be constantly running. Current temps are fridge 12, freezer -25, ambient 16. I haven't got anything in the freezer yet. Thermostat set on 1 (1-6 setting). How is the fridge cooled? When I removed the evap panel I could not see how cold air gets to the fridge. There aren't any holes in the fridge so I am assuming the back panel should be cooled. If the thermostat is u/s would the compressor still run? Does the thermostat control any duct vv from freezer to fridge back panel? I attempted to remove some of the insulation from the fridge rear but was worried about cutting anything under it so abandoned that. Wife now giving me grief. Pse help. Andy
Mar 02, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
See all Electrolux Icon 22.6 cu. ft. Counter-Depth Questions
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
838 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
