Question about Brother MFC-9440CN Laser Printer
Drum error - Brother MFC-9440CN Laser Printer
    President:
  • 548 Answers
Try replacing the drum. After this operation you have to reset the drum unit counter. Use the following steps in order to do that: Press Menu =
Posted on Aug 26, 2010
  • Florin Apetrei
    Florin Apetrei Aug 31, 2010
    I apologize because the solution above is incomplete.
    Here is the reset procedure after you change the drum:
    1. replace drum unit
    2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
    resetting without actual drum replacement might damage your printer.
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
Ricoh 5002sp error add toner and sc396
Drum motor error;
The machine detects a lock signal error from the drum motor for 2 seconds after the drum motor turned on.
  • Overload on the motor
  • Defective drum motor
  • Defective harness
  • Defective IOB
Try removing the drum and turning the gears.
May 01, 2017 | Ricoh Office Equipment & Supplies
Drum error dr-420
Sir/Madam
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
Brother Printer Support
Jan 14, 2014 | Brother Office Equipment & Supplies
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Apr 23, 2010 | Sharp AR-F152 Fax
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Nov 16, 2009 | Ricoh Aficio CL3500N Laser Printer
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Drum error
Yes, you should replace the drum unit if you have not done so. You may have a broken corona wire or drum. However, keep in mind that you will need to reset your machine after changing the drum unit. If after replacing, you still get the same error, you may have a problem with your machine properly sensing your drum unit.
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Brother MFC-9440CN Laser Printer Logo
219 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
