Question about Kyocera Mita FS-3830N Laser Printer
Printer kyocera 3830n will not print..display reads clean tonner waste bottle..i have emptied it and also cleaned it
    President:
  • 548 Answers
Try to reset the printer.
Factory reset on Kyocera FS-3800 printer:
Connect the printer via paralell and type the following in at the command prompt:
ECHO !R! FRPO INIT; EXIT;
Posted on Aug 26, 2010
I have a aficio mp c4000 printer/copier. it is telling me the waste toner bottle is full. where is the waste toner bottle?
The wast toner is placed next (next) to the first tray.
To reach there open the front door and you will see a screw (placed on top toward the main swith).
After unscrew you will be able to open a small door that hides the waste toner bottle.
Be careful because it is a little messy.
Good luke. If you need extra help reply to me
Mar 09, 2011 | Ricoh Office Equipment & Supplies
Where is the waste toner box on the Kyocera FS-3830N printer?
facing prnter look on left side. midway of side panal theres a door. push tab on door to the rear of printer a bit and door should open. depress plastic tab on neck of toner coleection bottle and pull out full bottle. replace or empty an dreinstall and cloe door. should reset and restart to ready condition.
Feb 07, 2011 | Kyocera Mita FS-3830N Laser Printer
Self test says 'check waste toner box'
It looks your waste toner box is full. Waste toner box collects toner drawn during printing. You have to remove waste toner bottle and empty it.
Follow the instructions to clean up toner bottle
http://www.kyoceramita.co.th/news/products/img_promain/20091141129533.pdf
Hope this helps
May 21, 2010 | Kyocera FS-C5030N Led Printer
Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Mar 10, 2010 | Kyocera Mita FS-3830N Laser Printer
MY fs3830n kyocera printer is dumping the toner
try emptying the waste toner bottle... if that doesn't work then change the drum... if that doesn't work then change the developer
Dec 22, 2009 | Kyocera Mita FS-3830N Laser Printer
Waste tonner tank
The waste toner container is inside the front cover at the bottom right. If you work for a business you should purchase a new one. If not you may be able to empty it into a another container and seal it before putting into the bin.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
Error mfessage: check wastt tonner bottle
Try a new bottle. I've seen where the there's enough old toner clining to the sides of the bottle that prevent the sensor from seeing through it. Of course the sensor and led may be covered with old toner. Get in there with a vacuum when the machines off and clean it out.
Mar 30, 2009 | Kyocera FS-3900DN Laser Printer
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Emptying waste tone cartridge
You need to replace the waste toner bottle (packaged with a new toner cartridge) you can't just empty it. There is a photo sensor that "reads" through a window of the waste bottle. The sensor could be dirty. Clean the slits with a q-tip.
Oct 01, 2008 | Kyocera Ai3010 Copier
Cannot print canon ir2200
toner waste bottle full. Take it out and clean it well particularly around the neck...which is where the sensor is.
Aug 17, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Kyocera Mita FS-3830N Laser Printer Logo
344 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
