Question about Electronics - Others
USB Drive not showing on my computer
When i connect usb flash drive it is not appearing in my computer. can you solve it.
  • 3 more comments
  • Anonymous May 08, 2008
    Computer doesn't recognize my Lyra X3030 usb? help
    I have moserBaer Pen drive and my computer is not able to recognise that . Please suggest the solution
  • Brad1983 May 10, 2008
    Having same problem, my computer is not recognizing my USG Flash stick, It is your brand and it is not working. I have a Compaq Presario with Windows ME. I need this problem fixed fast because I need to transfer a music file to another computer which does not have a floppy drive. I don't want to think that I wasted my money by buying this product because if so, I need to get my money back, I only bought this thing a week ago.
  • chrispap Sep 20, 2008
    the same problem and in the disc management doesn't have the option to open!!!
  • kgirl_64 Sep 23, 2008
    same problem. usb stick doesn't even light up.
(With device in computer) What you do is, right-click on My Computer, and click on manage. Then click on Disk Management, and when you can see the :C, and you right click on your USB, and click open.
Posted on Aug 24, 2008
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
I have a Lacie mosKeyto 8GB USB Flash Drive. When it it inserted into a PC it just does not show up at all, meaning computers do not detect it. What can I do? thanks
hi have you try connect it to other computer? if is working i guess your usb port have problem try to connect your flash drive to other usb port at the back your cpu. if not working your usb flash drive have problem. thanks
May 28, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
How to copy a doc. file to the flash drive.
Ok. here is what you need to do.
1. Hook your flash drive to any of the usb slot in your computer.
Wait for the system to read it. A green arrow icon will appear in the taskbar to show that a new removable hardware device is connected. After it successfully recognized, It will display a message " The device is installed and ready to use" at the lower right portion of the windows taskbar.
Click on My Computer a new drive will appear. It is usually designated as removable drive. On this drive you will paste the copied doc files. It is the assigned drive for your flash drive.
So go on., copy all the files you need to carry and paste it in the flash drive.
Be reminded also that before you unhook the flash drive from the computer, right click first on the green arrow icon on the taskbar and stop the operation. Click stop on the flash drive. This will turn off the remaining applications / readings in the flash drive and will prevent it from crashing and file corrupting.
I hope you understand.
Please give me some good ratings as this will help me too.
Thanks.
Aug 14, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
MY USB FLASH DRIVE IS DETECTED BUT CANT BE SEEN ON MY COMPUTER? HOW WILL I FIX IT TO RECOVER MY FILES.. HELP ME PLS
(Windows 7) - Control Panel - ( make Large Icons) - Folder Options - View (check "Show hiden files,folders and drives"). Then go to C:\\ and look for "Ur-Smart Data" Folder (Delete it). (That's solution!) for more contact me : resul-rustemi@hotmail.com
Feb 16, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
TRANSCEND PEN DRIVE WHEN CONNECTED TO THE USB PORT POP-UP MENU DOES NOT APPEAR ON THE SCREEN PLS REPLY
There are two possible reasons either your pen drive is not functioning or the auto play is disabled.
First of all check whether the Pen Drive is listed on my computer as a removable drive. If so then do the following steps:
1) right click on the properties and select "Auto play" tab.
2) On the dropdown choose mixed content.
3) Under "Actions" select "prompt me each time to choose an action" button.
4) Apply and OK
Now remove your Pendrive and reconnect.
This should solve your problem.
If your Pendrive doesnt show up on my computer there can be two reasons. either the USB port you are connecting is faulty . try a different USB port. or your pendrive is faulty which needs replacement....
Jul 23, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Drive No Longer Appears as an Available/Accessible Drive
goto disk management - right click and choose assign/change drive letter
Mar 18, 2009 | Electronics - Others
About Pen Drive
1. Connect the USB drive.
2. In XP, select Start>Programs, right-click My Computer, and
select Properties. Click the Hardware tab, then Device Manager. In
Vista, click Start, type device manager, and press <Enter>.
3. Find the drive under ‘Disk drives’.
4. Right-click the drive and select Uninstall.
Confirm by clicking OK.
5. The final step: Unplug the USB drive,
and then plug it in again. The drivers will
reinstall automatically.
Feb 04, 2009 | Transcend (589307) Media
XP (SP2) not recognising Maxell USB Flash Drive 2.0
whan i fix my usb in computer and try to open it ,the message appear "please insert a disk into drive d".
what is it? how could be solved this problem? help me
Mar 30, 2008 | Electronics - Others
Electronics - Others Logo
296 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
