Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
A glass broke in my dishwasher and it soulds like there is still some in the bottom, it is making a grinding noise when I run it. What should I do, can I unscrew the arm on the bottom to check under there?
  • LG Master
  • 909 Answers
The front kick panel and the lid and the 2 side panels are required to be removed. Once off, the small motor drain pump motor) in the middle of the frame needs to be removed to access the impellar. Once off, you should see small pieces of glass. Remove and check in the area. Reinstall then remove main wash motor. Once off you will also see small shreds of glass. Remove and check in the area for more pieces. Reassemble base and test before the panels are all put back.(Be exact when reinstalling motors).
Posted on Aug 25, 2010
1 yr old kitchenaid KUDE70FVSS2 dishwasher just started making grinding noises when the pump runs during the draining cycle and some water remains in the tub now. no issues with operation until now. i...
your better off just replacing the pump. you probably have broken glass or something else stuck inside the pump. to get to it you're going to have to remove the kick panel from the bottom of the machine. just follow the drain hose and you will see the pump.
Jul 16, 2011 | KitchenAid KUDE70FVSS Builtin Dishwasher
Grinding noise in chopper, Maytag 200 Quiet series
Please let me know what you did to fix this...I am having the same problem with ours. I noticed a recall on the same model just with a plastic tub. Thanks..
alisiajan@gmail.com
May 24, 2010 | Maytag Dishwashers
Dishwasher makes grinding noise when running
Sounds like you have debris like broken glass in the chopper assembly of your sump assembly. Best of to call a Certified Repair Company such as Sears if you are not mechanically inclined.
Mar 20, 2010 | KitchenAid Dishwashers
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
Mar 13, 2010 | Maytag MDB9600A Jetclean II Built-in...
Making grinding noise when started
Sound like you have a bit of broken glass or a fruit seed caught in the drain pump. Remove the filter and in the sump there should be a non return valve. Remove this and have a look for any foreign particles. Start the unit up without the filter and non return valve in or the bottom basket. Allow to run for about 10 sec. then open the door and hopefully the unit has thown out the noisey culprit. Have good look around the base and sump of the unit. Glass is also hard to spot as well. hope this helps.
Jan 24, 2010 | Maytag PDB3600A Built-in Dishwasher
Grinding noise from bottom inside during wash cycle.
Something is caught in the pump portion of the washer.
Should be a propeller type disc at the bottom.
Check it for clogs or someting caught.A peice of broken glass or a straw,ive seen forks get caught there.
Hope this was helpful.
Jan 17, 2010 | Dishwashers
Loud noise
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Maytag dishwasher mdb56000aww
It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
May 08, 2008 | Maytag 24 in. MDB5600A Jetclean II...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
88 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
