Non-labeled diagram of motherboard - Computers & Internet
    President:
  • 548 Answers
It is a very an old question. I had this problem myself at an early age.
Here is an image that will help you:Non-labeled diagram of motherboard - 59ae22f.jpg
These are small, 2-pin cables that are in Red, Blue and Green colors (with white main connector). Try to not bend te pins receptors, because they are very fragile.
1. Plug the POWER_SW cable on the first two left pins;
2. Plug the HDD_LED cable next to it;
3. Plug the POWER_LED cable either to the insulated 2-pin slot or next to the two others you plugged in;
Be carefull because if you missplace the order your system won't power up, and insert them horizontally.
If you need further assistance please leave a comment.
Posted on Aug 26, 2010
Need a wiring diagram for rheem electric water 50 gallon 2007 model
1) Copy following links for standard wiring that applies to all brands electric water heater: wire colors vary, and do not matter.
You probably have ordinary residential non-simultaneous water heater.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Look at tank label.
Typical label will show number of elements (upper and lower)
And give wattage for each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html#label
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
Notice also total connected watts.
If total connected watts is same as individual upper or lower element watts, then you have ordinary residential non-simultaneous tank.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 07, 2013 | Water Heaters
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
WHERE CAN i DOWNLOAD A DIAGRAM THGAT SHOWS WHERE THE PWR SW LED AND OTHER PLUGS PLUG IN AT
You can usually get this information from the manufacturer's website. In your case it would be Gigabyte's website. You will likely have to jump thru their hoops of answering question about your motherboard so that they can direct you to the correct page. You likely find it in an area labeled "Support" or "Drivers & Downloads". The motherboard usually has those pins labeled already though. Its sometimes hard to see the labels because the print is so small.
Aug 14, 2010 | Gigabyte GA-8LD533 Motherboard
Motherboard diagram with labels missing
Download the manual directly from Asus. Click on the link provided below; http://www.asus.com/product.aspx?P_ID=DwQbLuB78OdZD3VT&content=download
You will need to download and install Adobe reader to view the pdf file/manual. Adobe is free at; http://www.adobe.com/products/reader/
With Adobe you can zoom in and out making it much easier to see the details of you're motherboard. Oh and everything is labeled.
Cheers'
Mike
Mar 02, 2010 | ASUS P5V800-MX Motherboard
Pulled power and led cables off and do not know where they go
If you are lucky the connectors from the front panel may have labels on each connector to indicate what each connector is for.
The motherboard front panel connector pins should also be labelled too.
If not then go to the MSI WEB site to download a motherboard diagram for your model motherboard.
Oct 19, 2009 | MSI : 7125-040 (K8N NEO4-F) Socket...
I unplugged the some of the wires to install a new hard drive the wires i unplugged are the power wire reset wire and i need the diagram to show me how to plug them back in right so my pc will turn on
1. Go to: http://download.aopen.com.tw/Default.aspx
2. In the drop-down menu labeled "select a product", select "Motherboards".
3. In the drop-down menu labeled "select a Model", select "AX4SPE-N".
4. In the drop-down menu labeled "Category", select "Manual".
5. Download the first item on the list: "English Manual for AX4SPE-N
6. On page 22 of this manual, there is a connection diagram for the front panel connections, which you refer to in your question.
Jul 11, 2009 | AOpen AX4SPE-N (91.8AT10.701) Motherboard
Draw and label an intel motherboard
Please send us the model number of the mother board you need a diagram of, if you don't know it please send us the make and model of your computer. Do you need a specific model diagram of a cretin motherboard or do you need a diagram of Commonly used parts in a Computer. It would also help us help you if you can tell us what you are trying to accomplish or archive with a diagram of and Intel motherboard.
Intel motherboard diagram
Link above should help you identify some parts associated with an Intel mother board.
Apr 28, 2009 | Intel Motherboard
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Mother boards
For K8M-800M:
  • See the following diagram and try to make connection
183ab55.gif For complete manaul click.
Thanks
Iqbal
May 26, 2008 | Intel Motherboard
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
