Question about Dell Latitude D600 Notebook
Ac power supply
Does best buy sell a replacement ac adapter for this notebook
  • chasegman May 05, 2008
    dell lattitude d600
  • Dell Master
  • 5,568 Answers
Most retailers are unlikely to have the correct one in stock unless it is very common.
Here is one of many sources -
http://www.laptopbatteries.com/laptop-batteries/dell_latitude_d600.asp
Posted on May 05, 2008
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
Hi there, When plugged in nothing happens. What could it be?
Only a few things come to mind:
1. The plug on the MB is defective
Solution: Have the plug on the motherboard replaced
2. The universal power adapter is defective
Solution: Buy an ASUS power adapter and test it out. If it doesn't work, return it. If it does, then get rid of the universal adapter.
Good luck
-Carlos:
Jan 07, 2010 | ASUS AC Adapter- Universal Notebook AC...
Dell d600 will not power up. When connected to AC power the green led will go out. Is this a jack problem or a internal supply or what???
well, if you try more than one wall outlet and you have that issue, it is possible that you may have a bad plug. you can always buy a power supply at radio shack or best buy. and test it. or the best solution is go to a local computer repair shop, i'm sure they have plugs to try and see if it powers up.
Oct 17, 2009 | Dell Latitude D600 Notebook
Mikomi TV power pack/transformer/AC adapter replacement
Power Plus Online sell a replacement ac adapter 'PSU 1' at www.power-plus.tv we purchased one recently for £29.95 and this works fine.
Regards Steve
Oct 06, 2008 | Televison & Video
The AC adapter that I brought from Best Buy doesn't have enough power to get my computer to- charger-up. The S/N of my computer is T3A6931000974. The tec from best buy said that the adapter didnt have...
Looks like a 90 watt AC adapter will do what you need
http://www.batteryfuel.com/ac-5001sp-gateway-mx6955-laptops-90w-universal-notebook-ac-adapter.html
Sep 05, 2008 | Gateway Computers & Internet
AC ADAPTER
The AC adaptor is a 9v 2.2a AC adaptor. You can also use a 12v 2.0a AC adaptor.
These are available at just about any electronics retailer.
Nov 17, 2007 | Insignia IS-PDVD10 Portable DVD Player
Wont come on
The fact that the light on the power supply is a brighter green and them dims when plugs is certainly a key factor. I would say there are three possible problems. 1) The first problem to check is by far the easiest. Try removing the battery from the laptop and then hooking up the power supply. Do you get the same result. If it works then replace the battery. Problems two and three are unfortunately a lot harder to tell without having a spare power supply. Not to sound stupid but you've either got a problem with the power supply or laptop. If it is the laptop then you'll likely want to toss it out as you would need to send it off for repair. If it is the power supply then that can be replaced fairly cost effectively. Places like best buy and radio shack sell universal power adapters for laptops which could be used to test for the power supply being the issue. Perhaps you could bring it to the tech bench at best buy and ask if they have an adapter you can try before you buy. Radio shack might also let you do the same thing. If all else fails, perhaps you could return the adapter if you purchased it and it didn't solve the problem. Good luck.
Sep 04, 2007 | Acer Aspire 1642WLMi Notebook
Dell Latitude D600 Notebook Logo
Alun Cox
